Old 03-31-2020, 02:01 PM   #1
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
Shower leaking
Just when everything seems to be working right.....it starts leaking. I had a slow drain and put draino in it to clear the clog...it worked...almost to good...now I got a leak under the motorhome. Everything is wet under the Airstream for now so have not looked under it yet.
Anyone who has dealt with a leaking shower drain, please reach out. I suspect its the coupler or pipe that connects it to the gray water tank. There is an elbo someplace....digging through my owners manual tonight.
Mike
Mike1997 is offline   Reply With Quote
Old 03-31-2020, 05:04 PM   #2
Mollysdad's Avatar
I posted this in a similar question:
I had a recurring leak in the shower drain of my previous MH. The shower had a brass fitting with threads and the drain connected with ABS pipe which ran horizontally. It always cracked at the junction. As I drove the MH flexed enough to tug on the pipe and eventually crack.
Finally I made a flexible connection between the brass drain fitting and the ABS drain pipe using a common rubber joint.
The good news was the shower had an access panel under the shower so I could lay on the floor and see the drain pipe.
NO MORE CRACKS!
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
Newbie with leaking shower faucet aftermath Sinks, Showers & Toilets 4 10-04-2009 05:39 PM
Leaking shower StanandLynn Plumbing - Systems & Fixtures 7 08-13-2008 02:38 PM
? Leaking shower cubicle AirStrmFltRN Sinks, Showers & Toilets 4 06-07-2008 11:12 PM
Part missing? leaking shower connection glacierrunne Sinks, Showers & Toilets 3 07-18-2006 09:33 PM
