Old 03-22-2020, 09:22 PM   #1
Reformed Engineer
EngiDent's Avatar
1967 26' Overlander
Spartanburg , South Carolina
Shear pin on Power Gear bedroom slide motor shaft
Hello
I just posted this, but best I can tell, it has vanished... so, sorry if double-posting.
We have a 2000 Land Yacht 34ft (Ford V10 chassis.) It has 2 slides... the problematic one is the rear curbside bedroom slide. Evidently the shear pin on the motor shaft is sheared. It is a single Power Gear unit. My questions are..
1) How in the world can I get this gear off the shaft without removing the entire mechanism from the slide??? The gear is underneath/inside the rail. I tried removing the motor assembly from the rail and driving the shaft back through the gear, but I can't get a good enough "swing" at it due to poor clearance from the bed frame itself. Surely there is some method of removing the gear without removing the entire mechanism from the slideout???
2) How can I find the part number and a vendor for this shear pin?
3) My theory about what caused the pin to shear is that the floor may be swollen / "bucked" up due to water leakage thru shower skylight. Is that possible? What else could be putting drag on it? Seems like bottom of "nightstand" is digging into carpet.
Any and all help greatly appreciated-- thank you
David
Spartanburg, SC
EngiDent is offline   Reply With Quote
Old 03-22-2020, 09:43 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
This may help.
old powergear electric slide out.pdf
Power Gear is now Lippert Components. They were helpful when I contacted them several years ago: LCI- Customer Service <customerservice@lci1.com>
Al
Old 03-24-2020, 04:48 AM   #3
Reformed Engineer
EngiDent's Avatar
1967 26' Overlander
Thank you Al. That explains why Google kept bringing up Lippert when I would search for Power Gear. I'll contact them. David
KT Lock vertical shaft/locking pin problem kwinton80 Doors & Locks 1 03-12-2017 08:48 PM
need a dual shaft motor air-head Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-02-2014 09:09 PM
Hensley self tapping shear bolts adonh Hitches, Couplers & Balls 24 04-17-2012 11:01 PM
Wiper Motor Pivot Shaft realpank Argosy Motorhomes 3 08-05-2008 06:35 AM
