Old 03-03-2021, 01:47 PM   #1
2000 31' Land Yacht
Salida , California
Rub Rail or Waist Trim?
Another question about something that needs attention on my LY30. This trim strip that runs around the coach has started to come off. front The bumper piece has completely fallen off and the curb side is about half way there. What is the procedure to either replace or reattach this? It seems fairly rigid and along with the weight is seems like it would be a challenge to re-attach. Ideas anyone?
N8DAV8R is offline   Reply With Quote
Old 03-03-2021, 01:58 PM   #2
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
It is a peal and stick product. Must clean old tape from alum extrusion completely before trying to install new trim. I don't think you should try to re-attach failing trim strip. they carry replacement trim at Out of Doors Mart.
Steve
heslinhotel is offline   Reply With Quote
Old 03-03-2021, 02:06 PM   #3
1989 29' Excella
1999 25' Safari
N8DAV8R
That is a peel and stick trim (possibly a 3M product). Old tape probably dried out causing it to come loose. If you want to re-attach you must clean and remove old tape from Aluminum extrusion and the trim. Temp fix with double sided carpet tape might work short term, but you should replace trim. It can be ordered from Out of Doors Mart.
Steve
Old 03-03-2021, 02:52 PM   #4
2000 31' Land Yacht
Salida , California
Thanks for the pointer to check out Out of Doors. I guess I should abandon hope of finding even a close color match. I'll get away with black on the sides, but the front bumper piece is wider and it looks like they only have blue, maybe orange.
Old 03-03-2021, 03:07 PM   #5
1994 30' Excella
Mississauga , Ontario
If it is a rubber like moulding strip and flat on the back it can be reattached with an automotive adhesive. I can’t think of the name right now but it is yellow in colour and smells like rubber cement when wet. You put it on both surfaces, wait till tacky and stick it on. I used this ten years ago and it is still good. Might be called weatherstrip adhesive.
Al
Al and Jean
TAC ON-3
Old 03-03-2021, 03:18 PM   #6
2000 31' Land Yacht
Salida , California
Al
Does Scotch-Weld neoprene contact adhesive ring a bell as the product you used?
Old 03-03-2021, 06:02 PM   #7
1994 30' Excella
Permatex weatherstrip adhesive yellow 80br.
Al
Al and Jean
TAC ON-3
Rub rail trim , Should these be sealed ? nickclifford Leaks - Weatherstrips, Gaskets, Caulks & Sealants 22 04-05-2021 10:49 AM
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Rub Rail Trim JudgesArgosy Argosy Motorhomes 11 01-26-2013 09:43 AM
Rub Rail aka Body Trim aka ??? ukinusa Ribs, Skins & Rivets 3 02-16-2011 05:42 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
