RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-22-2020, 02:20 PM   #1
1994 36' Land Yacht
Kingsport , TN
Power steering and brakes
I have a 1994 Land Yacht on a p30 chassis. The power steering is beginning to whine a bit along with the brakes when they are applied. I assume the fluid is low but cannot finr the fluid reservoir anywhere. Any ideas?
Frank Statum is offline   Reply With Quote
Old 11-23-2020, 05:23 PM   #2
Kvsterling's Avatar
West Chester , Ohio
Mine is an older generation, but uses 1 resivoir for both power steering and brake booster. It is a vertical cylinder in front of the firewall on the driver side
Sounds like air in the system. I had to jack up front wheels off ground, run engine and turn left and right lock to lock.
This burps the system and you can add fluid until itís full. Had to do this about 50 times, but it works
Kvsterling is online now   Reply With Quote
Brake and power steering questions Mr. D Airstream Motorhome Forums 3 03-26-2015 07:23 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
Power steering problem on my "NEW" 345 JBK Mechanics Corner - Engines, Transmission & More... 19 10-23-2006 09:54 AM
Power Steering Fault. canny_banjo_man Mechanics Corner - Engines, Transmission & More... 2 05-09-2004 01:17 AM
