Old 11-03-2019, 02:55 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Onan starting issue
I just picked up a 2000 Land Yacht and have a question on the Onan diesel 7000 watt generator. Generator worked fine when I picked it up but after 600 miles and at home it will not start. It fires on one cylinder and will continue to fire as long as I hold the start switch on. It dies as soon as I release the switch. Fuel gauge is over half and much more than when I picked it up so i don't think it is low fuel.
Any thoughts?
2004 Excursion 4x4
Old 11-04-2019, 06:12 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Not sure since you never posted the model of the generator but many Onan gensets will not keep running if they're not producing power. As soon as you let off the starter they'll stop.
Here's a link to a great site that's dedicated to generators and older machines:
https://www.smokstak.com/forum/forumdisplay.php?f=1
92landyacht is offline   Reply With Quote
Old 11-04-2019, 07:36 AM   #3
HowieE's Avatar
Images: 12
7.5 HDKAJ11541F
I would assume the generator would at least see the convertor in the MH as a load on startup.
Is there any type of lockout that I have overlooked?
2004 Excursion 4x4
Old 11-04-2019, 07:43 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
First thing to check is proper oil level. They have a safety shut down for low oil.
mayco is offline   Reply With Quote
Old 11-04-2019, 08:13 AM   #5
HowieE's Avatar
Images: 12
Level is down to just about add a quart.
What grade oil is recommended?
2004 Excursion 4x4
Old 11-04-2019, 08:23 AM   #6
mayco's Avatar
I use 15/40 in mine but I think any good engine oil will do.
Old 11-04-2019, 08:48 AM   #7
HowieE's Avatar
Images: 12
A little dinosaur fat did the trick.
Now on to winterizing the ice maker
2004 Excursion 4x4
Old 11-04-2019, 08:55 AM   #8
mayco's Avatar
Nice!
Old 11-04-2019, 01:37 PM   #9
1992 36' Land Yacht
Grayson , Georgia
Yep, it's usually the easy things with those. I'd go to the web site I posted and pick up a manual for that genset. They have a listing posted somewhere and they do come in handy. No power generation and low oil level are common fault systems that will inhibit running. The fault I was referring to had nothing to do with load. It has to do with whether the unit will produce voltage or not. No AC output = no run. Same with the low oil level indicator. Low oil = no run as you have found out.
Edit: Here's a link to the operators manual for the Onan HDKAJ model generator
https://www.twinslan.net/~n0nas/manuals/onan/981-0161B%20Onan%20HDKAJ%20HDKAK%20HDKAT%20HDKAU%20Mob ile%20Genset%20Operator's%20manual%20(08-2005).pdf
And here's the service manual:
https://www.twinslan.net/~n0nas/manu...0(07-1999).pdf
Any idea on the Onan not starting? Coachmiami Generators & Solar Power 3 02-13-2017 07:52 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Dangerous Onan generator issue linda7915 Land Yacht/Legacy Motorhomes 5 12-05-2013 08:19 AM
Starting up trailer questions pompaneaux Electrical - Systems, Generators, Batteries & Solar 24 06-10-2010 12:08 PM
Onan Genset not starting Nick Danger Mechanics Corner - Engines, Transmission & More... 8 04-15-2006 07:40 PM
