Originally Posted by Mike1997
You might want to reach out to the Freightliner customer service folks in South Carolina. When the chassis was made the dashboard gages were considered part of the warranty on the frame. They will want the Freightliner serial number in order to answer questions.
The VDU was supplied by Freightliner as part of the incomplete chassis but it was then mounted by the coach builder.
It was mounted on the basement support ahead of the battery compartment and accessed by opening the battery compartment door just behind the rear wheels. It is squeezed into a thin compartment but can be removed with a socket wrench and easily identified by the red and green 1/4” air lines that feed into the lower section of the VDU or VDC. Both wire connectors clamp to the receptacles on the top.
