Lighted Grab Handle
Just wanted to share a couple pics of a project just completed. I installed a couple T10 led lights to the grab handle by the door (one in the top, and one in the bottom), and a couple led strip lights to light up the step at the same time. Thought this was a good ideal. Instead of having the "patio" light on and shinning into the RV parked next to me in the evening while I was out. This way, the handle and step are lite when I return in the evening, and also the key hole is lighted. Not to hard to do. Just replace the "patio" switch inside the door with a SPDT switch. Reinstall the power wire to the middle terminal, the "patio" wire to the bottom terminal, and connect a new wire to the top terminal to the T10 led in the handle, and also one for the step led strip lite. Just make sure you connect all your grounds.
