I bought a new pigtail with the black connector to the ignition switch, cleaned the contacts on the red wire male end on the ignition switch and installed the new pigtail. The red wire doesn't seem to be overheating but we haven't been on any long trips with driving 6 hours or so.
The pink wire mentioned above comes off the blue connector and, as mentioned, had been fixed some time ago by the PO. I wonder if any others have had problems with the red wire coming off the black connector to the ignition switch. As schmaco mentions, this red lead - if the Workhorse service manual schematics are correct - power the brake, marker and directional lights on the chassis.
Schmaco, if you do find that you installed a second relay somehow for this circuit please let us know. The pink wire isn't the only lead that seems to be able to overload/overheat, or so it seems at least on my LY.
Thanks for the replies!
