Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 05-03-2011, 08:13 PM   #1
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Hot/Cold Shower
We're on the road again and discovered a new problem and need advice and experience for an easy fix.
While showering, the pump stops and starts and goes Hot to Cold in spurts. Aggrivating for sure, but why? The shower is on full, but apparently not using water fast enough. Or is there another cause for this problem?
Tomorrow I'll take the head apart to see if there is an obstuction of water,
but I don't think so, because I get a good flow.
Any experience and solutions out there?
Paul
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 05-03-2011, 08:58 PM   #2
2005 28' Safari
saline , Michigan
It sounds like the bypass valves around the hot water tank were not put in their proper position after winterizing. Generally they are set in a certain position to avoid filling them with anti-freeze. But you have to put them back or you will get the problem you are experiencing. That happened to me once several years ago. It should be an easy fix if that is what it is.
Kosm1o is offline   Reply With Quote
Do you use your shower? Scott J-24 Sinks, Showers & Toilets 117 01-16-2012 04:43 PM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
Original Shower Curtain for 1967? star kitty General Interior Topics 3 02-19-2011 08:49 PM
