Upgrade your 'converter'... order one with stages.. Thusly..
https://www.progressivedyn.com/rv/po...er-converters/
You will need to plug the coach in to run the Converter.. or, arrange other method (your choice)
The converter runs all 12VDC in your coach.. and maintains the battery level. (of course you still need to ensure electrolyte, battery terminals, etc are in good order)
If battery subject to freeze, remove and put where it won't freeze. Get a 'battery tender'.. or similar to 'maintain' a trickle charge.
Lots lots more to learn, but themz the basics.
