Old 07-03-2020, 07:22 PM   #1
2001 31' Land Yacht
greensboro , North Carolina
dash air/engine processor LY30 2001
still no air!! put on a set of gauges to confirm system was charged. gauges read a static pressure of around 110 on the low and high side. I think this is in the ball park, since today was around 90 degrees. since the clutch does not engage, the pressure doesn't change when engine is running. found an electrical wiring diagram in the manual, of course the wire colors don't match what is actually on the MH! anyway, found the location of most of the air conditioning parts. with the key switch in the IGN "on" position and the air conditioning selector switch on "max air", I traced the 12v to the thermostat, low and high pressure switches. all seem to be working. the output of the high pressure switch, according to the wiring diagram, goes directly to the a/c clutch, and engine processor. the a/c clutch connector does not have 12v. I applied 12v directly to the a/c clutch, and the clutch engages. I assume the 12v to the engine processor is to signal the engine processor to increase engine speed due to the clutch being engaged. my question is, does the engine processor also send 12v to the a/c clutch on a different wire? does anyone have a ideal where the engine processor is located?
dongw is offline   Reply With Quote
Old 07-03-2020, 07:44 PM   #2
2018 25' International
Slidell , Louisiana
Good news you have good offline pressure. Leaks are so much worse than mechanical or electrical issues. Also great that the clutch is fine as that is not much fun replacing either. Generally the engine processor does not so much activate the a/c but it does cut it off if the throttle position etc. calls for max output. If your description is accurate, it does sound like the processor cut-out circuit is the issue. i would first look at a fuse or relay as the issue since computers don't have anything capable of the higher current required to pull in a mechanical clutch...
Brian
BayouBiker is online now   Reply With Quote
Old 07-04-2020, 05:54 AM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The power feed from the AC clutch should come from a relay which also powers the electric fans in front of the AC condenser. Regards, Bob
bobmiller1 is online now   Reply With Quote
Old 07-04-2020, 10:56 AM   #4
2001 31' Land Yacht
have any ideal where the a/c relay would be located?
Old 07-04-2020, 10:58 AM   #5
2001 31' Land Yacht
any ideal where the a/c relay is located?
Old 07-04-2020, 09:58 PM   #6
Slidell , Louisiana
usually in the main fuse box in the engine compartment. I am not familiar with your set=up so I can't be sure.
Brian
Old 07-05-2020, 05:41 AM   #7
bobmiller1's Avatar
Not on your motor home, but usually if you follow the power feed from the AC clutch or the electric fans in front of the AC condenser you will find it. I would think it would be around the radiator vertical support right (passenger) side. Regards; Bob
2001 dash air conditioner dongw Land Yacht/Legacy Motorhomes 3 06-22-2020 07:05 PM
Bathroom Door Measurements on 2001 LY30 airstreambob Land Yacht/Legacy Motorhomes 3 09-03-2019 06:35 PM
Air conditioner processor cutbrain Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-25-2011 09:45 PM
RAM & Processor Upgrade... Andy R Forum Admin, News and Member Account Info 3 05-09-2004 07:17 PM
Help! Where can I find the nutone food processor? cmgirdwood Nu-Tone Appliances & Central Vac System 8 02-04-2004 10:23 AM
