Old 10-28-2023, 11:49 AM   #1
1995 30' Limited
1995 31' Land Yacht LE
Parrish , Florida
Airstream land yacht le series. Need help
I'm new to the rv world. Got a very good deal on this air stream. Needing someone willing to chat awhile and maybe answer my 100 different questions lol
Dniver0513 is offline   Reply With Quote
Old 10-28-2023, 06:13 PM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Ask away. Present your questions here so others may learn from the discussion.
92landyacht is offline   Reply With Quote
Old 10-29-2023, 06:31 AM   #3
1995 30' Limited
Parrish , Florida
95 land yacht
Does the ceiling lights run off of shore power some how? Or is it strictly the batteries?
Old 10-29-2023, 07:48 AM   #4
1992 36' Land Yacht
Grayson , Georgia
The lighting inside the motorhome all run off the coach batteries. The coach batteries are charged whenever the coach is plugged in, or the generator is running. The device that charges the batteries also provides 12V DC power to all of the fixtures that use 12V. The device is called a power converter/charger.
Old 10-30-2023, 07:34 AM   #5
1995 30' Limited
Parrish , Florida
where is the converter/charger located?
Old 10-30-2023, 08:49 AM   #6
1992 36' Land Yacht
Grayson , Georgia
Most of the power converters are located behind the panel in front of the passenger's seat. How about some detail on why you're asking? Do you not have 12V coach power? Are the coach batteries not being charged when plugged in?
The older converters were known to fail over time. Newer converter/chargers are more sophisticated and provide a better charge profile. I changed mine a couple of years ago to a IOTA DLS-55 and added the IQ4 module for better battery management.
Old 10-30-2023, 10:10 AM   #7
1992 36' Land Yacht
Grayson , Georgia
Here's a link that may help you as well. It's the owner's manual for the 1995 LE.:
https://www.airstream.com/wp-content...manual-202.pdf
Old 11-30-2023, 07:52 AM   #8
1994 35' Land Yacht Diesel
Hudson , Florida
hi 92 LandYacht
2 Mornings now , cold temps in Florida , with drive Button not activating drive - worked be noon yesterday - thinking about cigarette lighter heater on the buttons might work
Jeannie Lamb is offline   Reply With Quote
Old 12-02-2023, 06:59 PM   #9
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
Thats an Allison Transmission and it has a reset feature and can tell you if the transmission level is low. I have the original manual from Allison and will be glad to look this up if needed. It has a sequence using the buttons to reset.
Mike1997 is offline   Reply With Quote
Used Airstream Land Yacht RV 300hp Diesel Motorhom REPO SUsed Airstream Land Yacht RV eBay Watch Airstreams on eBay 0 12-20-2011 02:40 PM
Used Airstream Land Yacht RV 300hp Diesel Motorhom REPO SUsed Airstream Land Yacht RV eBay Watch Airstreams on eBay 0 11-09-2011 05:10 PM
Airstream Land Yacht Diesel Repo Slide out Wash/dryer SAirstream Land Yacht Diesel R eBay Watch Airstreams on eBay 0 08-04-2011 08:10 PM
2002 airstream land yacht xc365 s2002 airstream land yacht xc365 eBay Watch Airstreams on eBay 0 07-22-2011 10:10 AM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 02:50 PM
