Hi all,
I'm new to rv'ing so maybe I'm not doing something right, but here goes...
I got this LY about a week ago and wasn't sure how to plug it into the house to get power. I finally figured out I needed an adapter to fit onto the big black power cord so I could run an extension cord from the house to the RV. Done.
The door steps had been working when I opened the coach door, the fridge was working also. There was this AUX battery switch that was in the down position. I read in the manual that it should be up if the motorhome was in use, so I pushed it to the up position. When I did that, the steps stayed in the up position and won't come down when I open the door, and the fridge lights went out. As far as I can tell, all other things in the coach work.
What did I do wrong? I unplugged the AC, started the RV engine, and started the generator. When I did that two days ago, the steps worked and the fridge worked, but not now.
Are there some breakers or fuses somewhere I need to check for the fridge? Are the steps frozen?
