Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 11-14-2011, 07:30 PM   #1
JMSx2's Avatar
2005 30' Land Yacht Gas 30
Belgrade , Montana
2005 Land Yacht 30'
Just bought the AS and want to drain the water heater and water tank - any idea where the drain plug is for the water tank??
JMSx2 is offline   Reply With Quote
Old 11-14-2011, 07:37 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Congrats on your purchase.
You can use the search button on the top of this page to find info on all systems on you Airstream.
The outside access door on the Airstream will give you access to the WH drain and anode rod. The water tank will drain in the area of the sewer dump valves.
Do you not have an owners manual????
This one should be close enough.
http://www.airstream.com/files/libra...bd7de00a37.pdf
AND THE 2005 IS HERE,
http://www.airstream.com/files/libra...68e745770e.pdf
Dave
masseyfarm is offline   Reply With Quote
Old 11-15-2011, 04:00 AM   #3
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
JMSx2, congratulations on the new coach. We have had ours a couple of years and really enjoy it.
On my 2005 Land Yacht, the water pump, fresh water tank drain, and hot and cold water drains are behind the door at the foot of the queen bed.
Be careful removing the plastic plug in the water heater. It is easy to round over the corners. After the water heater tank drains, there will be close to a quart of water remaining in the bottom of the tank. This needs to be flushed out to remove calcium deposits left behind in the water heater. The bypass valves for the water heater are accessed inside the coach beside the water heater.
As you winterize, don't forget the filter in the faucet at the kitchen sink.
Sam
Airstream12557 is offline   Reply With Quote
Old 11-15-2011, 08:46 AM   #4
JMSx2's Avatar
Belgrade , Montana
Dave
We do have a manual but could not find what I was looking for. The location you mention makes sense!
Tinbad :: 2005 A.S. Safari Del Gurney Airstream Registry Discussions 0 08-19-2011 08:32 AM
Mary Joan :: 2005 Airstream Safari SS wrochdvm Airstream Registry Discussions 0 08-19-2011 08:31 AM
Lovely Rita :: 2005 Clasic thetahoen Airstream Registry Discussions 0 08-19-2011 08:31 AM
Wild Thing :: 2005 Airstream Classic DL46 Airstream Registry Discussions 0 08-19-2011 08:31 AM
2005 Classic S/O nswhite Airstream Registry Discussions 0 08-19-2011 08:31 AM
