RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-23-2018, 09:56 AM   #1
1981 28' Airstream 280
San Francisco , California
Zerk fitting on water pump and dash/engine powered a/c unit
Folks wanting to grease the Zerk fitting on the water pump. I canít see it from underneath or with the interior lid open. Wondering if I need to remove the entire lid and the section itís attached to. If so the back section that the lid is attach to on my rig is completely carpeted - can anyone explain if it does need to be removed how to do it. Donít want to tear all the carpet off if not necessary. Thks!!!
Next my dash engine powered A/C does not work - fan spins but no A/C. I have the Isuzu diesel. Does anyoneís dash A/C still work?? Is it worth getting it serviced??
Many thanks to all for assistance! Best and thanks, Dave
redfalcon507 is offline   Reply With Quote
Old 05-25-2018, 10:54 AM   #2
Magnet18's Avatar
Churubusco , Indiana
Airstream owners manual should show you how to take the doghouse apart, on mine the front section with the radio slides straight back, you might need to undo a couple screws first
Shouldn't be any need to de-carpet anything
PO had my AC converted to the new stuff, looks like original compressor larger condenser, works great
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is online now   Reply With Quote
Old 05-25-2018, 10:56 AM   #3
Unfortunately it all depends on what some PO might have done to the doghouse. Some get boxed in with items built around it that would make removing the engine easier than dismantling the doghouse!
Old 05-26-2018, 02:24 PM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Not sure if you were able to get access yet but the grease fitting on the water pump is on the top
mayco is offline   Reply With Quote
Old 05-26-2018, 05:11 PM   #5
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
He told me he was off camping probably with little internet access. Can you believe the nerve of some people off playing while the rest of us are holding down the home front.
Cheers, Dan
~ Margaret Thatcher ~
retro fitting a ducted A/C unit? Starstream Furnaces, Heaters, Fireplaces & Air Conditioning 10 06-24-2015 11:42 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
'02 LY 26', engine won't turn over, no power to dash kardy Land Yacht/Legacy Motorhomes 6 01-28-2014 10:58 PM
2011 Airstream Interstate 3500 B Van Powered By Mercedes Benz Diesel Engine eBay Watch Airstreams on eBay 0 10-01-2011 03:00 PM
Hitch Zerk Size jsamuel8 Hitches, Couplers & Balls 8 07-01-2010 02:24 PM
