Old 08-11-2020, 03:30 AM   #1
1983 31' Excella
1992 35' Airstream 350
Plymouth , Massachusetts
Worth It Or Not ?
Hi Guys,
I have the opportunity to purchase a 1987 34.5 Airstream Classic motorhome for $10,500.00 asking. The body is straight , the clear coat is in tact. It's being kept under a tarp.The interior is clean with minimal wear.It'sioned with the garbage compactor and separate ice maker.The fridge is newer and works.Dash air does not...no surprise here. The mileage is 123,000. The tires are shot. The frame is clean however I did find a couple of spots on the lower rockers with some rust through. One of the large storage drawers won't slide fully out.One of the rear corner window has been replace but improperly installed by the DIY owner. They replaced the airbags and the gas tank during there ownership Sounds like a good deal. Here is the catch. The older couple (80s) that have owned it for 23 years have not used it in "several years". Other than an "occasional move up or down the driveway". It will crank but only if the carbs are primed.I am trying to guesstimate what it will take to make it road/travel worthy. The couple are unwilling to allow it to leave the property to be mechanically inspected as it is not registered.Having parted with my 91 35 LE 10 years ago . I am not current on what $$$$ might lie ahead, Advice ?
Angeline350 is offline   Reply With Quote
Old 08-12-2020, 05:39 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
Images: 51
Rivet
Originally Posted by Angeline350 View Post
Hi Guys,
10500+20000=30500 plus labor. Are you ready for that? Or find one in the 30k-40 range enjoying someones countless hours doing a thorough resto. Anything in between is just that.
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-12-2020, 02:28 PM   #3
Paul J Mauro's Avatar
1985 34.5' Airstream 345
Bolton , Massachusetts
I agree with others that this is a project 345 you could look more for one that has been cared for .very easy to drop 20k to 30k getting the engine tranny brakes and other major stuff done .i would NOT buy this if you are not a tinkerer .read how many of us did belts ,plus manifold bolts and yes I did a brake job on the side of a mountain .otherwise I love my 345 had it since new in 1985 not an adoption a natural birth
Paul J Mauro is offline   Reply With Quote
Old 08-12-2020, 03:25 PM   #4
Long Island , New York
Outstanding!
Peter
Old 08-13-2020, 03:18 AM   #5
1983 31' Excella
Thank you. I have come to the same conclusion .
Old 08-13-2020, 02:04 PM   #6
Thumbs up
Good move IMO, thanks for the update.
Enjoy your new-found thousands of hours of free time!
Happy trails,
Peter
Worth it or Not Angeline350 Airstream Motorhome Forums 4 08-11-2020 03:33 AM
Found a shell but not sure if it is worth it? karendee Dollars & Cents 9 01-04-2010 03:30 PM
Worth fixing up or not?? HELP! rjmiester Trailer Values 38 11-12-2009 04:18 PM
Worth fixing or not. chapparel Dollars & Cents 8 11-02-2006 09:31 AM
Worth a look... canny_banjo_man Airstream Motorhome Forums 4 11-12-2002 09:34 AM
