Old 06-17-2020, 04:34 PM   #1
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Wonít start!!!
Wonít start or turn over. Weíre caroling this weekend and may have a little trouble getting going home in the next day or so. May have to just stay here!!!!
Iíve always wondered why there are two starter solenoids on our 1987 345. Thereís one on the starter and one on top by the air cleaner. We have the banks power pack so the headers ore there heating things up nicely. But all heat shields are in place and everything is wrapped up nicely for protection. The starter and both solenoids were replaced about 2 years ago but here we are dead again. Why are there two solenoids? How can I hit wire it to get going?
1987_345 is offline   Reply With Quote
Old 06-17-2020, 04:52 PM   #2
2018 25' International
Slidell , Louisiana
The relay by the air cleaner is to allow for low current through the keyed ignition switch. That relay provides higher current sufficient to power the solenoid magnet that will both actuate the shift lever to engage the clutch and drive gear and push the high current contacts energizing the motor coils.
If the upper relay is bad you can jumper around it with a 10 or 12 gauge wire to energize the lower solenoid. If that one works you will hear the shift arm move and click. If the start brushes or coils are burned out the motor won't turn and a new starter is in your future.
Brian
Old 06-17-2020, 07:50 PM   #3
1986 34.5' Airstream 345
Londonderry , New Hampshire
There is another solenoid that can connect the house batteries to the
chassis battery. It is operated by a toggle switch in the glove compartment.
You would use it if you ran the chassis battery down trying to crank
over that big 454. It is a big help on a cold night. This solenoid
is mounted on the back of the battery tray.
Air345Fly is offline   Reply With Quote
Old 06-18-2020, 07:00 AM   #4
Kenneth
1987_345's Avatar
Waxahachie , Texas
Thanks Bayoubiker. Since both solenoids and the starter were replaced less than 2000 miles ago Iím assuming I may have a short between the key and the upper solenoid. Iíll jump it to get going and when I get home if I canít find the problem I may have to just put in a started button for reliability. Do you think there is any need to protect the wiring around the starter from the heat of the headers besides the heat shield that was provided?
Old 06-18-2020, 07:54 AM   #5
Slidell , Louisiana
If the wires are not touching the heat shield, no need. they can touch the engine block etc, no problem. They are good to 90C and the heat shield blocks the radiant energy which is the biggest issue when there is an air gap to work with.
Brian
Old 06-18-2020, 05:52 PM   #6
Kenneth
1987_345's Avatar
Waxahachie , Texas
Ok thank-you. We got home safely. I touched a screwdriver from the small terminal on the left to the large terminal on the left and then turned the key all the way to start. It started right up. I guess I may need to put a jumper between those two left terminals
Old 06-18-2020, 07:02 PM   #7
Kenneth
1987_345's Avatar
Waxahachie , Texas
I changed my mind on the jumper. I need to trace the wires back and try to locate the trouble. Could anyone provide me with a 1987 starter solenoid/relay wiring diagram?
Old 06-19-2020, 05:46 AM   #8
Slidell , Louisiana
Glad you made it home and the screwdriver trick indicates the starter and main solenoid is good. I used to use the screwdriver trick all the time back in my high school days and have a couple melted ones to show for it. I was reluctant to suggest that because the current is so high, and crawling under there is nasty. I don't know where to find the service manual and diagrams, but I wish you luck.
Brian
Old 06-19-2020, 11:29 AM   #9
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Wonít start!!!
Fwiw, I did not know that this relay existed until a mechanic found it for me. I was in a hurry to get going, he could not find a direct replacement, and I am still running with the jumper that he installed. Please post the solution when you figure it out.
Waipio Rim is offline   Reply With Quote
Old 06-19-2020, 12:13 PM   #10
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
1987 Service Garage manuals for Electrics, Emissions, Driveability, Unit Repair and Service repair. Look for the P series stuff.
http://www.73-87chevytrucks.com/tech...lete_11x17.pdf
http://www.73-87chevytrucks.com/tech...air_Manual.pdf
http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
http://www.73-87chevytrucks.com/tech...iveability.pdf
Boom Sounds is offline   Reply With Quote
Old 06-19-2020, 05:56 PM   #11
Kenneth
1987_345's Avatar
Waxahachie , Texas
Thanks guys for all of the valuable info. I searched through the existing threads until late last night and discovered some interesting information. Apparently when AS put these units together, they didn't use a very beefy ignition switch and the upper starter relay was a mod to compensate for it. I really don't have much knowledge when it comes to trouble shooting electrical components, but I can change out parts! What I also found were a couple of threads that talked about replacing the factory starter with a 1995 or later high torque starters. They are smaller, stronger, and claim to draw less energy to complete the task of spinning these big 454's. The space savings will help me keep out of the header tubes as well. I gathered up all of the parts and will attempt the change over this weekend if the rain holds out. I'll keep you posted. Thanks again, Kenneth
Old 06-19-2020, 06:14 PM   #12
Slidell , Louisiana
The high torque starters are better, Honestly mostly because they are smaller, but hey any port in a storm so.... remembering back to my drag racing days. they still pull a lot from the ignition so the key ignition switch is remains the weak point.
Brian
Old 06-20-2020, 03:42 AM   #13
Suggest add heat shield if not already in place. I think still useful for smaller starters. Lack of heat shield is common cause of large starter failure as they warp and suffer heat damage
Old 06-20-2020, 04:05 AM   #14
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Best to get rid of the stock type starter asap. I just replaced mine with an expensive Mean-green. Cheaper versions are available, but this is the end of your troubles. Either way, take your time to make sure your new starter is shimmed out properly, especially if the engines was rebored
https://www.mean-green.com/searchqui...words=MG6510HD
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-20-2020, 07:35 AM   #15
Kenneth
1987_345's Avatar
Waxahachie , Texas
Right. The banks system provided a heat shield which I did put on but I'm figuring I may need to modify it to fit the smaller starter
Old 06-21-2020, 08:45 AM   #16
Kenneth
1987_345's Avatar
Waxahachie , Texas
Smile Project complete!!!
Ok so here's how it went yesterday. The project to replace the starter took about 3 hours but it also included an oil change. First I disconnected the cranking battery and replaced the faulty starter relay which is the one next to the air cleaner. I would to also note that I decided to remove the rubber pad that is between the relay flange and the channel piece that it's mounted to. I think that it's so important that this component has a good ground that I don't want any rubber in the way. So I made a spacer out of steel that would give it the height it needs but help it be super conductive as well.
Next was the starter which was a 1995 or later model starter. I removed the OEM starter as well as the heat shield that came with the headers. I also noticed the old starter had two shims under it that I set aside to use with the new one, only the shims didn't fit the new starter and the new starter didn't come with any shims of it own. When I tried to put the new smaller hi-torque starter on, the holes wouldn't line up because of the torque converter pan so I removed it. Without the pan in place the new starter bolted up perfectly, and without any shims. I reconnected the wiring just as it was on the old one and reconnected the cranking battery. Then I disconnected the ignition at the distributor because I didn't want the engine to start as I tested it, I just wanted to see how it cranked over for now. To my surprise when i turned the key the engine turned over perfectly and whisper quiet! I reconnected the ignition plug at the distributor and started the engine. It operates perfectly and has never turned over this smoothly and quietly since I've owned the MH.
Now for the heat shield. I'm not sure I even need it anymore because the closest header tube is now over two inches away from the starter and I would think that enough heat would dissipate given that much space even sitting still in the heat of summer. But I was able to trim it up a little with tin snips and bend it making it smaller and then reinstalling it. I had to mount it under one of the starter mounting bolts and am not completely happy with that install. I fear t will vibrate and ultimately fail. I think I may make an additional bracket for it to go under the bolt for the transmission dip stick tube. But before I go to that much trouble I will probably see if I can find a factory heat shield for the smaller starter.
Lastly the torque converter pan. All I had to do with it was trim about .25 of an inch around the hole that the starter pokes through, then it when back on fine.
I'm very happy with this mod and hopefully the starter problems I've been plagued with for awhile are finally over. We'll see. Thanks again for all of your help and I hope this conversion can help you all as well.
Old 06-21-2020, 10:10 AM   #17
Airstream Driver
1994 30' Excella
Images: 51
Originally Posted by 1987_345 View Post
... I had to mount it under one of the starter mounting bolts and am not completely happy with that install. I fear t will vibrate and ultimately fail. I think I may make an additional bracket for it to go under the bolt for the transmission dip stick tube. But before I go to that much trouble I will probably see if I can find a factory heat shield for the smaller starter.
When I modified the original heat shield for the smaller starter, I left a 1" strip of metal in the back that I bent 180degrees and used a big hose clamp to tighten it to starter body. Worked well.
AIR #13
Old 06-21-2020, 11:01 AM   #18
Waipio Rim's Avatar
Honokaa , Hawaii
What relay did you find as a replacement? Mine had no markings.
Old 06-21-2020, 02:01 PM   #19
Kenneth
1987_345's Avatar
Waxahachie , Texas
It's actually a standard Ford relay. I think they are universal having two battery posts and two smaller posts. The only difference in most of them is how they mount. Just take it into your local parts store and they can match it up for you. They're around $8
Old 06-21-2020, 03:11 PM   #20
Waipio Rim's Avatar
Honokaa , Hawaii
Thanks. Mine is different, but I will have to figure out the wiring and use one like yours.
A/C start-up w/ soft start Pimms Electrical - Systems, Generators, Batteries & Solar 21 06-11-2020 09:55 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Aaaargh!!! Motorhome won't start!!!! AGAIN!!! eraffety General Motorhome Topics 14 01-19-2003 06:40 PM
