Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-22-2021, 01:43 PM   #1
City , Missouri
What Does Everyone Use To Jack-Up Their Camper?
I'll need to pull the wheels off on my new-to-me 290. What does everyone use to jack up the motorhome and support it to safely work under it?
Thanks!
Silver Hare is offline   Reply With Quote
Old 12-22-2021, 03:19 PM   #2
ITSNO60's Avatar
Tucson , AZ
I've been using floor jacks and 12 ton jack stands. Depending on your weight be advised that jack stands are rated as pairs, a set of 12 ton jack stands are only rated at 12 tons when used as a pair. This week I plan to buy a 20 ton bottle jack, air over hydraulic as my floor jacks really have to work hard to lift the rear of my MH. It can be a challenge to lift and place a jack stand as often the lifting point is the same place you want to place the jack stand. Once it's up in the air some folks put the tires underneath for added safety if it should fall.
Brian
ITSNO60 is online now   Reply With Quote
Old 12-22-2021, 03:50 PM   #3
Antsville , FUBAR
Welcome Aboard👍
I use floor jacks & jackstands...one I've had for 30yrs, the other a newer 'old fart' jack.😂
ID:	409653   Click image for larger version
ID:	409655   Click image for larger version
Old 12-22-2021, 04:05 PM   #4
2015 25' Flying Cloud
Schaumburg , Illinois
Thankfully I’ve not had to do it myself yet, but I do carry a small hydraulic bottle jack for that purpose, just in case. One important caution is be sure you lift it from the trailer frame, do NOT lift on the axle. You risk permanent damage (bending) if you lift on the axle. I attended an informational session hosted by dexter axle company at the last international rally and the presenter repeatedly emphasized that point.
1StreamDream is offline   Reply With Quote
Old 12-22-2021, 04:06 PM   #5
1986 31' Sovereign
Miami , Florida
The OP has a motor home — whole different critter…
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 12-22-2021, 04:58 PM   #6
ITSNO60's Avatar
Tucson , AZ
Is that the 22 ton Esco air over hydraulic? I want one.
Brian
Old 12-22-2021, 05:18 PM   #7
Kevin245's Avatar
We don’t have a MoHo, but on the farm we have tractors, large trucks, and trailers. We use floor jacks for lifting, and jack stands for secondary support.
Just so you know, ASME PALD testing typically requires that devices successfully complete a series of tests at 1.5X of the published rating. So there is a safety factor buried in the design. I still use a secondary support, just in case.
William C. Swinney
Old 12-22-2021, 06:11 PM   #8
ITSNO60's Avatar
Tucson , AZ
Is that true of Harbor Freight products?
Brian
Old 12-22-2021, 07:31 PM   #9
2007 22' International CCD
Anything from Harbor Freight that’s used for lifting big heavy objects needs to be backed up by something that can be trusted like heavy timber racking.
Old 12-22-2021, 08:06 PM   #10
Antsville , FUBAR
YES...👍
Old 12-22-2021, 10:13 PM   #11
Oops. I missed that detail completely, sorry about that
Old 12-23-2021, 11:18 AM   #12
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
One other (possibly to obvious to be mentioned ....) point is that whatever surface the jack is going on needs to be pretty sturdy. You are putting a *lot* of pounds per square inch on the bottom side of that jack .....
Old 01-05-2022, 01:41 PM   #13
2021 16' Caravel
2022 23' Globetrotter
Callao , Virginia
So, where do you put the stand if you lift the TT with a bottle jack under the lift point? 2022 Globetrotter 23FBT.
kmrice is offline   Reply With Quote
Old 01-05-2022, 04:46 PM   #14
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you get one of these (the black/silver unit on the left) you don't need a separate jack and jack stand. I used two of them to change out the axles on my 25-ft trailer. Of course, as you can see by the yellow/orange jack stand I used a jack stand anyhow since I tend to be a belt & suspenders kind of guy.
The jack/jack stand combo easily lifted my 25-ft trailer from the jacking point and there is a built-in jack stand which can be set to automatically latch into place as you lift the trailer.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is online now   Reply With Quote
Old 01-05-2022, 05:04 PM   #15
Kevin245's Avatar
Yes that is true of HF products. Automotive lift devices go through an extensive test regimen, and the providers we consider low end work hard to pass the tests.
William C. Swinney
Old 01-05-2022, 05:07 PM   #16
Kevin245's Avatar
Any portable lifting device should always be backed up with appropriate secondary devices. Mechanical things can always fail.
William C. Swinney
Doesn't everyone talk about their first time?... Road trip, that is... Hawk-ination Sprinter and B-van Forum 17 08-18-2019 02:04 PM
How did everyone come up with names for their trailer? Hopeful1 Airstream Lifestyle 216 07-02-2019 07:00 PM
How is everyone insuring their airstreams? gomotomoto On The Road... 20 04-08-2019 08:00 AM
Does anyone use their bumper storage for anything except hoses? WILDRTEXAS Bumpers & Bumper Storage 46 03-26-2015 02:56 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
