Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-10-2021, 07:51 PM   #1
20 year member!
1990 34.5' Airstream 345
Marina Del Rey , California
Water pressure regulator failed, 1990 345LE
I wonder if anyone has had a failure of the Watts Regulator city water pressure reducer valve? (I'm now working on refurbishing the water system) - I tried filling the tank with the autofill switch last weekend while on a test drive to a RV site overnight - it always used to fill to about 3/4 full back when i first owned this coach in the 90s. But this time, it autofilled to about 1/4 fill and stopped. Then, when i disconnected the hose from the camp site faucet and turned the water pump on in the coach, i found that water was spurting back out of the fill hose. This stops when i turn off the water pump. I *think* that that there is a 1 way valve in the Watts device, if i remember, which would make sense if the regulator has failed (it's completely corroded), also possible is that the autofill valve has failed, but I'm not so sure about that. Here's a couple of photos...anyone seen this?
ID:	388441   Click image for larger version
willhenshall is offline   Reply With Quote
Old 02-10-2021, 09:47 PM   #2
Magnet18's Avatar
Churubusco , Indiana
Yes, there is a check valve in that
A pex ball type check valve + camco regulator is an easy solution
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 02-11-2021, 12:52 AM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Throw the watts regulator in the garbage and install a camco check valve. Upgrade the auto fill solenoid to 1/2” or 3/4” for filling the tank faster. The auto fill uses the crappy sensor system that Airstream installed when new in conjunction with the circuit board installed over the stove. If it doesn’t work try a Sea-Level system for replacement, but at least filling the tank will only take 5 mins instead of 20, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 02-20-2021, 08:58 PM   #4
20 year member!
Many thanks for advice - here's what worked!
The Camco check valve and a new pressure regulator and a whole bunch of messing about with pex cinches fixed the problem! All good now. I also found that the whole of the rear curbside floor has been getting wet for years due to the overflow outlet at the top of the water tank (that spits the water back out when the tank is full) was almost off. So whenever the tank was being filled instead of water being expelled from the little hole below the filler in the eternal curbside body, the overflow was mostly going into the compartment. I think the coach floor structure is not too affected. I'll keep an eye on it. However, the rear curbside compartment floor has completely rotted. So i'm getting that repaired/refabricated this week. Photo of that also below.
I also discovered that there is another input connection on the water tank at the top rear on the back side that is nothing connected to it. it is pluggd with a square black plastic screw. but the actual connector is loose and leaking. I'll be epoxy gluing that back on tomorrow. As always it's a privilege to have access to the wealth of knowledge in this forum, many thanks to all that lean in and help! Warmest, Will
ID:	389100   Click image for larger version
Old 02-21-2021, 08:15 AM   #5
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Good luck on the floor repairs. Here is what a little water leaking looks like, over 3/4 of the rear floor replaced!
I do not have the watts regulator anymore, it was gone when we got the coach. I always use a regulator on the hose connection to water source!
We had a hose burst in the night due to a high water pressure supply. Now always use the in line regulator!Click image for larger version
ID:	389125Click image for larger version
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 02-21-2021, 08:22 AM   #6
cmadmaxman's Avatar
All PEX now, with no more plastic fittings!
Both of my fill hoses just fell of when I moved the tank!Click image for larger version
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 02-21-2021, 11:39 AM   #7
cmadmaxman's Avatar
Fill hose and vent!
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Water pressure regulator used to regulate air pressure? Atsushi Winterizing, Storage, Carports & Covers 8 10-26-2018 08:16 AM
Does on-board water pressure regulator protect against excessive air pressure? Hermes Winterizing, Storage, Carports & Covers 2 10-07-2018 03:25 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
