Old 08-27-2019, 08:49 PM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
waste water valves
I haven't posted about our trip out west, and I will eventually, but need some assistance.
My blackwater tank is now leaking past the shut off, (nice surprise); I looked at the Classic stickies to find information on what type of shut off they are, but couldn't find out any info.
Camco sells a three inch shut off valve at CT, link below. Will they work or not?
https://www.canadiantire.ca/en/pdp/r...-0408303p.html
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-27-2019, 10:27 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The trailers from that era use Thetford valves. I do not know what the MH used. Available from Amazon and from Outdoors Mart. I ordered mine from Outdoors Mart since I knew they would have the right one.
Bill M. is online now   Reply With Quote
Old 08-28-2019, 12:42 AM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I think the originals were Thetfofd, mine were white body and larger in physical size than the Valterra or Camco, the drain hose connection was also larger. I changed mine to Valterra as they are about 1/3 the cost and much easier to find. The spring lock clips on the T handles are Thetford but the tread on the shaft is the same as the Valterra.
Cheers, Dan
~ Margaret Thatcher ~
Old 08-29-2019, 06:54 AM   #4
Magnet18's Avatar
Churubusco , Indiana
Tony, I did this job last winter, I'll dig up what info I have (buried somewhere in my thread?
Not fun, but all things considered not a terribly difficult job
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 08-29-2019, 08:13 AM   #5
1981 31' Excella II
New Market , Alabama
Get one of these for emergencies. These are life savers. Do you have a center bath or rear bath. I ended up using the old Thetford valves since I have a center bath and things are shoe horned in there pretty tight.
Perry
Old 08-29-2019, 09:30 AM   #6
Magnet18's Avatar
Page 32 of my thread begins documenting the fun I had with this
http://www.airforums.com/forums/f311...178802-32.html
Tl;dr, just order this
https://www.etrailer.com/RV-Sewer/Valterra/T84B.html
The old ones are held in with a hose clamp and vulkem, disassemble and crawl under with a heat gun to work them out, installation is the reverse of deintegration
The parts that slide into the tanks are 3" spigots, i ended up with hardware store fittings between the two valves but I think the linked fitting would have saved me time and money
-Rob
Old 08-29-2019, 10:20 AM   #7
1981 31' Excella II
Here is my adventure. The Thetford flanges were already there so it was easier to replace same with same especially since my tank pans were not coming out unless I broke every bolt holding them up.
http://www.airforums.com/forums/f444...th-109487.html
Perry
Old 08-29-2019, 11:24 AM   #8
Dazed and Confused
Isuzusweet's Avatar
Huh, a PO must have changed things a bit. I have LaSalle Bristol 3" waste valves. I've order 2 replacements.
I should be able to loosen stainless steel screw ring clamp on tank side; undo four bolts holding waste gate in, remove and insert new waste gate, and bolt everything back up.
This is where I should do a Mayco and say "easy peasy"; shouldn't take 10 minutes. But I know better than to say that.
Bought two new valves with seals and bolts for $61 and change, Canadian, delivered.
I"ll let you all know how it goes.
Cheers
Sidekick Tony
Lube waste water drain valves Bluto Waste Systems, Tanks & Totes 10 08-02-2019 05:45 PM
Placement of waste water release valves rowdyATX Waste Systems, Tanks & Totes 2 01-30-2018 03:26 PM
West Boondocking Waste Water and Food Waste Disposal Ray Eklund Boondocking 2 10-18-2015 02:38 PM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
