Old 10-30-2018, 09:36 PM   #1
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Vents
Does anyone know of a source for the chromed plastic louvered vents behind our front wheels??? Thanks, Charly
streamquest is offline   Reply With Quote
Old 10-31-2018, 04:54 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I think they are fairly standard marine louver vents available on eBay. I got some beige ones to add to Bella but then they could not be fitted on a small wheel Argosy.
martin300662 is offline   Reply With Quote
Old 10-31-2018, 09:39 AM   #3
Martin, would you mind expanding on why they won't fit on a small wheel Argosy? I have not yet tried to fit the ones I bought so now you've got me wondering!
bkahler is online now   Reply With Quote
Old 10-31-2018, 11:15 AM   #4
Keen amature
1975 20' Argosy 20
Chestfield , Kent
They are normally installed slightly above and to the rear of the front wheels (first couple of louvers overlap) but this fouled the inner arch structure on Bella (to the rear) meaning the could only go above the front wheels and it seemed pointless when the primary purpose was to release the hot air coming through the grill and past the front brakes.
Does that make sense? They seemed to be cosmetic only in the location they would fit.
Old 10-31-2018, 12:38 PM   #5
Yep, makes sense. From what I remember seeing in pictures of Bella is the inner arch / floor area was done the way the 77 and later coaches were configured. Which is to say the floor runs all the way to the outer wall.
On mine the floor ends at the inner wall and the inner wall space is actually open from below all the way up to the bottom of the window frame. I'll have to check to see if that makes a difference in the placement of the vents.
Thanks for the info.
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Vintage Hehr vents silverhawk Roof Vents, Skylights & Fans 6 07-18-2005 02:37 PM
WHAT kind of roof vents on my 96 excella dufrain Roof Vents, Skylights & Fans 0 01-26-2003 03:57 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
