07-12-2017, 09:28 PM
1987 32.5' Airstream 325
Windsor
, Ontario
Vent fan
One of my vents has had the fan removed.
Does. Someone know were I can get a replacement?
Thanks in advance for your help
07-12-2017, 09:38 PM
1979 23' Safari
Wayland
, New York
07-13-2017, 03:04 AM
1984 27' Airstream 270
Scotia
, New York
I dont recall where I scavenged it, but I found a aluminum blade that is larger and has better flow than the original. It is fairly quiet too.
07-18-2017, 07:05 AM
Windsor
, Ontario
so I can hook up one of these fans that only has a "cigarette lighter" power plug.
These fans are readily available with, what looks like the same fan?
07-18-2017, 09:18 AM
1982 31' Airstream 310
champaign
I have parts off of two fans I removed. Can't remember exactly what is left, Ive given some away. What exactly do you need and I'll check what I have
Mike
07-18-2017, 09:39 AM
Richmond
, Kentucky
Mike
I've got remnants as well if needed.
1975 24' Argosy Motor Home
07-18-2017, 11:28 AM
Dazed and Confused
Hillsburgh
, Ontario
Just a suggestion, what about replacing it with a Maxxair fan? I replaced mine and added a second Maxx air in the back bedroom. The Maxxair has a 10" fan with variable speed, reverse direction, a cover that allows use of the fan in the closed position.
One of the best mods I've done to my coach.
Cheers
Tony
07-18-2017, 11:57 AM
champaign
Tony, how do you set it to get it to run with the lid closed? Mine shuts off when I close the lid. We may have different models of the Maxxair.
07-18-2017, 12:10 PM
Dazed and Confused
Hillsburgh
, Ontario
http://www.airxcel.com/maxxair/produ...maxxfan-deluxe
Cheers
Tony
PS @realpank: I'm in Hillsburgh and a friend in Lindsay are going to the meet in Cooperstown USA at the end of September; care to join up in a bit of a convoy?
07-18-2017, 12:33 PM
Richmond
, Kentucky
Tony, I didn't know you could keep up with Tony on the highway
07-18-2017, 01:36 PM
champaign
Yup, looks like you have a newer model of the Deluxe.
07-18-2017, 01:42 PM
Dazed and Confused
Hillsburgh
, Ontario
i'll admit I'm not the sharpest tool in the shed......Is realpank's name Tony?
Mike; I've been trying to out Allison your Allison for a while now.
Cheers
Tony
07-18-2017, 01:58 PM
Richmond
, Kentucky
Cheers
Tony
Let's try this again......
Tony, I didn't know you could keep up with JOHN on the highway
07-18-2017, 02:03 PM
champaign
Cheers
Tony
I'm ordering the newer model immediately
07-18-2017, 02:33 PM
Richmond
, Kentucky
Sheez, I think I'm going to go out and mow.......
07-18-2017, 02:42 PM
Dazed and Confused
Hillsburgh
, Ontario
@Brad,
I have a higher top speed than John, but only just barely as he has a bigger turbo and has turned up the tap on his fuel pump. For some reason he has no problem running at 2800+ rpms, where as I like the Mistress at 2250-2400 rpm; less hectic, more time to enjoy the sights and better mpg's; SO, this year he's behind me for the trip down and back.
Mike; dang it, I should have kept my trap shut.
Cheers
Tony
07-19-2017, 07:13 AM
Windsor
, Ontario
Vent fan
Tony,
Thank-you so much for the invite, September not good for me this year. Would love to go one of these days. Will be at Pinery Labour Day(and week prior)
Chris
07-19-2017, 01:04 PM
Windsor
, Ontario
Thanks again Tony,
Took a quick search on Kijiji and found a Maxair fan and vent that I just met and bought. Any tricks/tips to installing(came with no instructions) but looks straight-forward. Or any threads on the forum?
07-20-2017, 07:39 PM
Dazed and Confused
Hillsburgh
, Ontario
Take your time and use a Fein saw to cut the hole bigger as it has to be 14" square and the OEM hole is not. Have a friend hold a piece of wood as close to the saw blade as possible from down below to cut down on the aluminum flapping around, as you cut from up above; also watch out for wires. On a scale of 1-10 for difficulty, it rates about a 4. Just take your time and cut a 14" square piece of wood to act as a guide or pattern.
You'll love the extra airflow and quietness of the fan.
We have friends with a place to stay just below the Pinery's, maybe we will meet up. I'll PM you if we are going to be in the area.
Cheers
Tony
07-20-2017, 10:40 PM
Windsor
, Ontario
Thanks much Tony
"Fien saw", is the a "saws-all"? Or a jig saw?
I'm assuming saws-all with a longer blade.
Great tips, looking forward to, I had one in my Argosy and loved it!
