Old 10-01-2018, 08:30 PM   #1
1986 34.5' Airstream 345
Londonderry , New Hampshire
Updating the backup camera.
I am at the point of reassembling the rear body panel that I discussed
in my "stupid, stupid, stupid" thread. This question is as much about
technical issues as it is about style.
I took the original camera apart and it is in pristine condition inside.
The outside of the housing and mounting bracket have some rust.
Not too hard to sand and paint. I don't know if the camera works
but the whole system does not work.
Should I weld up the holes and use one of those small cameras mounted
somewhere else? Perhaps just above the spare tire? Is it violating
the AirStream Classic style to get rid of that great big brick hanging
off the rear end?
Should I put a modern camera in the old housing? Perhaps a security
camera like this:
HFW4239T-ASE
That one has much better low light performance. While I have it all
apart I can run a new cable for the camera.
Is there an advantage in having the camera mounted so high?
I was also thinking about some camera systems that also have cameras
looking back on each side of the vehicle to cover the blind spots.
Pete.
Air345Fly is offline   Reply With Quote
Old 10-01-2018, 09:23 PM   #2
Magnet18's Avatar
Churubusco , Indiana
If it was me, I'd put a new camera in the old housing. If you don't end up using the old housing, I'll take it, and use it to cover up my new camera!
I'd run hardwired since you have access, my wireless is a pain, too much interference
Advantage of having it up high is being able to see over the toad
Re: blind spots, my convex mirrors do a great job, i really don't have any complaints
Magnet18 is offline   Reply With Quote
Old 10-02-2018, 07:47 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I did essentially what Rob described. I mounted a new camera under the original sunshade so it looks original from a distance. I also added a side camera behind the front wheel well curb side. I hard wired over the roof and down through the fridge vent. Through the floor behind the fridge and popped back up by the heater core. That's where I located the control box. I used Rear View Safety equipment, been doing great so far, about a year now.
mayco is offline   Reply With Quote
Old 10-03-2018, 06:59 PM   #4
Here are some pictures of the original housing and camera;
The housing is 3 5/8" across, 4 1/8" high, and 8 1/4" deep on the inside.
There is a bracket in there for mounting the original camera that I would
remove.
Pete.
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 06:09 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
Intec backup camera Bill McNamara Airstream Motorhome Forums 2 04-15-2004 02:41 PM
