Old 05-10-2020, 02:11 PM   #1
1995 36' Classic 36
Batesville , Mississippi
Transmission lock/brake
1995 Classic Motorhome. When I put my shifter in "Park" position, the motorhome will still roll. Where/what is the electric switch that engages the brake?
Casey Lipe is offline   Reply With Quote
Old 05-18-2020, 09:58 AM   #2
SpiceStream's Avatar
1984 31' Airstream310
Sullivan , Wisconsin
Has the Trans been swapped?
Mine has an Allison 545 in it which has no "Park", it has a hand operated e-brake that can be used as a parking brake. my 545 was built with no Park.
My 310 originally came with a gas engine with trans that included Park, but it is no longer in the motor home. the other option could be that someone broke the park paul in your trans? Did park ever work?
SpiceStream is offline   Reply With Quote
Old 05-20-2020, 05:19 PM   #3
1995 36' Classic 36
All original everything including tranny. The issue is related to the P30 GM motorhome chassis. There is an automatic park brake that engages when you move shifter into P position. In activates something that uses power steering fluid! I found a diagram in an online service manual, but it's above my understanding. Some body somewhere knows about this, but I can't find them!
Old 05-20-2020, 05:26 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
That particular system has a very high failure rate and many owner have removed and replaced it with a manual set up.
Cheers, Dan
~ Margaret Thatcher ~
Old 05-20-2020, 05:36 PM   #5
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Now thats funny, since I just made a post about this and had a hard time figuring out what this de-activated system on my 92 350 is. Dan finally figured it out.
https://www.airforums.com/forums/f31...ml#post2360781
AIR #13
PeterH-350LE is online now   Reply With Quote
Help - Deadbolt Lock won't lock PSU1981 Windows, Doors, Locks & Vents 1 11-21-2016 12:04 PM
Updated keyless entry lock BAUER LOCK sc17842 Doors & Locks 6 03-22-2016 09:53 PM
Transmission and Brake Fluid aa9zz Sprinter and B-van Forum 4 07-17-2014 04:30 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
transmission revving high w. brake controller az-streamer Brakes & Brake Controllers 7 12-18-2009 11:31 PM
