Old 04-09-2017, 12:50 PM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Trailer or tow bar wiring
My 250 classic has a four pin round plug underneath the passenger side rear bumper. It all looks original. I assume it is for towing lights indicators, although I have not tried it yet. Has anyone else got one of these and which connector do I use to wire it up? I want to put a tow bar bike rack on the back of the coach. Like this.
https://www.thule.com/en-gb/gb/bike-...6-929-_-929021
Nick
Boom Sounds is offline   Reply With Quote
Old 04-09-2017, 02:49 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
That connector should have brake lights, parking lights, and left and right turn signals. If the tow bar is mounted to the rig, metal to metal, it should work. If not metal to metal you will have to run a ground connection.
2004 Excursion 4x4
Old 04-09-2017, 03:03 PM   #3
Thanks Howie - do you happen to know if the four pin connector is a standard US issue plug? I'll need to buy one to connect it up to my European tow bar.
all the best
Nick
Old 04-09-2017, 03:14 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The 4 wire connector should include. Left turn/ brake; Right turn/ brake; tail/marker lights and a ground/ common wire.
Old 04-09-2017, 03:53 PM   #5
Trnpk Crsr's Avatar
Baltimore , Maryland
all the best
Nick
Yes, the connector is a US standard. If you send me you mailing address by PM, I will sent you a connection kit or two. They are inexpensive, and available from most auto parts stores.
Regards,
John
Trnpk Crsr is offline   Reply With Quote
Old 04-09-2017, 05:57 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
Nick
I think this is this what you are looking for?
https://www.amazon.co.uk/s/ref=nb_sb...d+Trailer+Side
Alan
Old 04-10-2017, 05:32 PM   #7
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Here is a handy document I grabbed from etrailer:
https://www.etrailer.com/faq-wiring....70407-Wir-eduA
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 04-10-2017, 11:27 PM   #8
Thanks everyone
Old 04-17-2017, 06:58 AM   #9
Name:	ImageUploadedByAirstream Forums1492433851.625151.jpg
Old 04-17-2017, 11:34 AM   #10
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
The bigger issue that European tow hitches are attached to the tow bar, vs US ones are a receiver and a hitch, so I guess you have a 2" square opening where you need to insert a hitch so that the bike rack will have a ball to attach to, Nick
I have a US bike rack in storage in NJ (a Rola which takes a couple of bikes and even a tandem side one) and goes straight in the receiver. It even has a pass through to take the matching Rola hitch carrier (which I think is at Brad's)....jezz I have stuff scattered all over the eastern US!
martin300662 is offline   Reply With Quote
Old 04-17-2017, 12:33 PM   #11
Hi Martin - I've got the receiver hitch. In fact, I have a spare which you can have for free if you need one. Euro tow ball attached.
3 bike Thule bike rack is connected but not wired into that US connector below the rear bumper. In fact you could have the Thule bike rack when I'm done if u need it.
I'm assuming that the towbar electrics are fully operational.
I need to get a new 4 bike carrier (to accommodate Daughter's boyfriend's bike #i'mpaying) and then wire that into that connector and (hopefully) we'll be good to go for summer holidays.
Btw - Lyme Regis campsite is cracking but VERY tight to get up the lanes to it.
COYI
Nick
Old 04-17-2017, 03:49 PM   #12
Originally Posted by martin300662 View Post
...It even has a pass through to take the matching Rola hitch carrier (which I think is at Brad's)....jezz I have stuff scattered all over the eastern US!
That would be yes, it's at my place
Old 06-29-2017, 02:53 PM   #13
chriscraw's Avatar
1991 35' Airstream 350
Looking at which tow bar to go for when attaching my 2004 VW Beetle (manual shift of course).
Seems there are a number of manufacturers such as Blue Ox, Roadmaster, Demco etc. Has any ASMH had experience with specific brands or models. Just got a quote to fit a Blue Ox to the VW (plates, hitch, diode wiring etc.) as $1600. Reasonable?
chriscraw is offline   Reply With Quote
Old 06-29-2017, 03:24 PM   #14
HowieE's Avatar
Images: 12
First thing I would check on is the capacity of the tow bar. I think the Blue Ox would be overkill while towing a Bug.
I stand corrected on my earlier post about the 4 wire connector. Left and right turn signals also are the brake lights in all American cars. That leaves the other 2 wires for parking lights and ground.
Historically VW turn and brake signals were on separate wire. I do not know if that is still the case. Check it.
2004 Excursion 4x4
Demco Excali-Bar tow bar Denis4x4 Airstream Classifieds 0 05-03-2015 01:39 PM
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-02-2013 11:17 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
