02-11-2021, 01:34 PM
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Towing a Jeep Wrangler with a Classic 310
I bought a newer toy last weekend that my wife wanted it's a 2017 Jeep Wrangler Unlimited 4 door and was wondering if anyone has any input if this vehicle can be towed behind my 83 Airstream Classic 310 Cummins diesel allison auto. Thought if it will I can save a little on not having to buy something else. Any input will be appreciated. Thanks Jim
02-11-2021, 01:59 PM
Churubusco
, Indiana
If it's a manual, just put it in neutral
If it's an automatic no
1983 Airstream 310 Class A Motorhome
-Rob
1991 35' Airstream 350
Columbia
, Tennessee
I see a lot of jeeps on the road behind motorhomes, if 4x4 should be able to put the transfer in neutral, and should be good to go Jim.
You will need to put a brake system in the jeep for brakes! 2000 lbs with out brake assist on the toad. The jeep is what 4000 lbs?
Stopping will be your problem!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
02-12-2021, 10:29 AM
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Thanks ya'll for the help, now to get a tow bar system setup.
02-12-2021, 10:46 AM
Churubusco
, Indiana
Also do be sure to beef up the motorhome tow hitch. The factory setup is kinda flimsy and only rated for 2000lbs. There are some pics on here, it's not too complicated.
-Rob
02-12-2021, 10:59 AM
2007 30' Classic S/O
Somewhere
, South Carolina
The only comment and it's not first hand. If a manual trans make sure nothing inside the Toad can slide forward, hit the stick and pop it into gear. Like luggage, supplies stuff etc.
A co-worker told me this tale about this happening to his dad's Suzuki Samurai and it was spinning the engine IIRC backwards and ruined the engine. The "luggage/thing" moved forward while during a hard brake application hit the stick and put it in gear.
02-12-2021, 12:34 PM
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Thanks will check out the rating on my tow system on the RV. It is a automatic and I will make sure nothing is loose during tow for sure.
02-12-2021, 01:44 PM
Columbia
, Tennessee
If the OEM system has not been beefed up, highly recommend doing it. A PO had it break away on our 310! They had mounted the new system to low, I repositioned higher and added more welds and supports!
AIR Member 12654
1991 350LE "Zephyr"
02-12-2021, 02:00 PM
Columbia
, Tennessee
Here is what I have now.
AIR Member 12654
1991 350LE "Zephyr"
02-12-2021, 02:15 PM
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Thanks for the pic will get my welder buddy to take a look and beef mine up for sure don't want to lose a TOAD going down the road.
