I knew it was dicey if a RV place would allow my LP tank to pass inspection after the Ontario government clamped down on LP tanks and certification after the Sunrise Propane debacle.
While it is not necessary to certify the ASME tanks we have in our MH's as they are built stronger than a portable tank, they still have to be inspected by a licensed RV1 tech. If the RV1 tech decides that the rust pits are deeper than 40 thou, they will not service the unit or issue you an inspection steeeker.........No steeeker, no fuel.
Since the RV garage and tech's license is on the line if something should happen up to 6 months down the road, they are failing everything and demanding people get new tanks....PERIOD. You know where this is going.
Wouldn't have anything to do with the fact that the bloody people who inspect also SELL the bloody things.
I took my 310 into get the propane system checked as it does have a leak and needs a new regulator, fill valve and blow off valve for the tank. I entered the office and talked to the service writer who asked the year of the vehicle........I stated 1983.....without hesitation his head snapped up and stated categorically that I needed a new tank. I was shocked....did he not want to at least see the bloody thing first before he bent me over the bloody desk and had his way with me. Not even a feakin
for foreplay.
I demanded he inspect the tank first......He sent a tech out who didn't even bend down to look through the access panel......Yeh, you need a new tank.
FINE, I need a new tank....except I can't find one......
Does anyone know who sells a replacement tank 14" diameter by 60" in length?????.
