11-25-2020, 03:14 PM
#1021
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by bkahler
What reading are you getting on your dash volt meter?
For the first time ever over 13V on the dash gauge. Considering the need for best voltage with ignition on (levelers, air compressor) the need for max voltage is crucial on these complicated rigs.
AIR #13
11-25-2020, 03:57 PM
#1022
Richmond
, Kentucky
That's good news. It's hard to charge a battery when the voltage is less than 13 volts going to the battery.
1975 24' Argosy Motor Home
12-04-2020, 09:20 PM
#1023
1991 35' Airstream 350
Columbia
, Tennessee
Great to have the voltage where it should be!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
12-05-2020, 05:45 AM
#1024
Richmond
, Kentucky
I bet you have fewer battery issues now
12-05-2020, 05:53 AM
#1025
Airstream Driver
1994 30' Excella
Austin
I think Brad has been holding back this info since Jan 2003
AIR #13
12-05-2020, 11:09 AM
#1026
Richmond
, Kentucky
Considering how bad my memory is anymore the odds of me remembering anything from last week let along 2003 are pretty darn slim!
12-05-2020, 05:07 PM
#1027
Airstream Driver
1994 30' Excella
Austin
Need some input. This is a relay under the "hood" that is energized by Ignition on and run. I am able to trace the 10 gauge red wire passed the step to the back of the battery drawer area where it disappears in a massive wire bundle. This area also coincides with a big bundle of wires going inside the coach under the sink.
Disconnecting the + feed leaves inconclusive situations. On my 350 the lock mechanism on the dash and keyless pad no longer work, on Chris's 350 it still does.
I think it the feed for the lock module, but why do we get 2 different results?
AIR #13
12-05-2020, 05:56 PM
#1028
1982 28' Airstream 280
Port Angeles
In the words of our friend Bob, "Consistency ??? LMAO, Regards, Bob"
Cheers, Dan
~ Margaret Thatcher ~
12-12-2020, 12:10 PM
#1029
Airstream Driver
1994 30' Excella
Austin
Almost 1 year to the day since the "project" arrived in Austin on a Flat Bed trailer. Our late Sidekick Tony's comment was: "Peter , what are you getting yourself into, that thing has project written all over"
Well, Tony, I think you would be proud of me, seeing what all I have done cosmetically and mechanically. She runs like a true "Airstream Touring Coach" and all systems are go!
In this spirit, best Holiday wishes!!
AIR #13
12-12-2020, 01:29 PM
#1030
Churubusco
, Indiana
Nice!
She's a real beaut' Peter!
12-12-2020, 04:41 PM
#1031
Airstream Driver
1994 30' Excella
Austin
Originally Posted by Magnet18
Nice!
Thanks Rob! Its nice to get a little enjoyment from all that hard and difficult work and actually use it.
AIR #13
12-12-2020, 10:00 PM
#1032
Churubusco
, Indiana
Wait, you mean the hard work isn't the enjoyable part? I've been doing this all wrong
12-13-2020, 12:53 AM
#1033
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Looking great Peter.
Isn't this normally the weekend of the Blanco rally? Are you able to go ahead this year?
12-13-2020, 06:34 AM
#1034
Airstream Driver
1994 30' Excella
Austin
Good memory, Martin, yes it is! I did not call it this year for all the reasons. Just a buddy of mine in his trailer and us. Park is fairly full anyway. Next year hopefully should be a go and you may still be floating around the great South West
AIR #13
12-13-2020, 08:54 AM
#1035
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Fingers crossed Peter!
12-13-2020, 10:55 AM
#1036
Airstream Driver
1994 30' Excella
Austin
Had a great shake down trip and know what to concentrate on to make this 350 even more dependable.
One thing that has to go is the rubber hose mess at the new trans cooler, I installed a while back. Seems I can't get the fuel Injection type clamps tight enough. Had another leak and lost close to quart. I even stopped after 10 miles and checked everything, must have happened after that first check.
What is the best Trans cooler without the fixed hose nipples, I can "hard plumb" ?
AIR #13
12-13-2020, 12:07 PM
#1037
Foothill Ranch
So, are you planning on having a contest at the next Get Together to see who can remove/replace their generator the fastest?
I can throw a Kohler 7kw genset on the floor and break it faster than any man......
Seems I gotta catch up with Peters thread, as I am behind the curve....
12-13-2020, 02:47 PM
#1038
Columbia
, Tennessee
This is what I put on the 310. Also have a 14" puller fan that comes on at 180 and off at 160, Sensor at line input at radiator.
AIR Member 12654
1991 350LE "Zephyr"
12-13-2020, 02:59 PM
#1039
Columbia
, Tennessee
One of the advantages of having the vertical radiator on the 310, cooler bottom left hand in the photo!
AIR Member 12654
1991 350LE "Zephyr"
12-13-2020, 03:05 PM
#1040
Columbia
, Tennessee
AIR Member 12654
1991 350LE "Zephyr"
