03-19-2016, 09:59 AM
#421
Richmond
, Kentucky
Originally Posted by bkahler
Did it say somewhere in your instructions that you can't electrically reverse the fan?
I don't think mine came with any such info and I know I've reversed the direction on other fans that I've purchased. A little googling indicated that some fans can be electrically reversed and others can't.
I'll have to see if the ones I put on the Argosy are reversible. I'll let you know...
Peter, yesterday after powering up my test stand I found that the fans were blowing away from the radiator. I swapped the + and - connections and the fans started blowing air through the radiator. I guess I got lucky with mine.
1975 24' Argosy Motor Home
03-19-2016, 12:42 PM
#422
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Yes, indeed, you are a lucky dog.
But do you think the air volume was the same blowing the other way? When I reversed the blades on mine, I would only get a slight breeze...
Did you fire up your engine, too and i missed it? Please tell me that is not so.
AIR #13
03-19-2016, 02:07 PM
#423
Richmond
, Kentucky
Check out post 75
I reversed the wires right after shutting the engine down then turned the fans on. I believe I had a pretty good volume of air flowing through the radiator with the fans blowing towards the engine. The air was hot and I watched the temperature on the gauge start to drop. I might play with swapping the fan blades just to see what kind of flow I get. Can't hurt to try.
03-20-2016, 08:22 AM
#424
Airstream Driver
1994 30' Excella
Austin
When I am not tearing Airstreams apart, I still take my passion to my daily job in a much different way.
This Library needed some "magic" and we know that silver often does the trick. Here is the before, note all the different type of woods
3 month later, a "secret" formula to darken the wood and make it look like aged Ebony, thousands of small silver strips to gild all the highlights
and you have a one of a kind library
with a matching wallcovering to highlight the inside of the bookshelves
ok, back to the 310 and the 30' Excella
AIR #13
03-21-2016, 04:54 AM
#425
Dazed and Confused
Hillsburgh
, Ontario
A true master of all trades and jack of none.
Salute
Tony
03-21-2016, 05:59 AM
#426
1966 26' Overlander
Woodstock
, Georgia
Looks awesome Peter. I recently did a basement room with my limited skills, took a sad concrete walled room and painted the ceiling tiles black, left the white grid.
Repainted the walls a nice earth tone. Polished the concrete floor and added repurposed planks from pallets to 1 and a part of another wall. Built a bar to match. The pic is of the smaller wall with pallet wood..and a pool cue rack to match
Looks so much better now..fun project that took me a week. Retirement is awesome.
03-21-2016, 07:24 PM
#427
1979 24' Airstream Excella 24
Tipp City
, Ohio
Really cool Peter!
03-21-2016, 08:46 PM
#428
Airstream Driver
1994 30' Excella
Austin
Alan,
Wouldn't know about the retirement thingy , but you sure use your time well. Nice little pad down there in the basement. Now I know to stop by next time I am in the neighborhood.
AIR #13
03-22-2016, 06:07 AM
#429
1966 26' Overlander
Woodstock
, Georgia
you better! We have lots of room and you can even hook up your trailer or whatever you bring ...I actually am working full time for a few months, but I have enjoyed my time a lot.
Life is still good.
03-25-2016, 06:15 PM
#430
Airstream Driver
1994 30' Excella
Austin
Just about to finish the interior of my most recent "project", the 1997 30 Excella trailer, I bought AS IS.... This was a lot of work, all new plumbing, new flooring and fresh upholstery and blue leather accents.
To take the bathroom cabinet apart is a major job and even bigger to put it back together. I stayed with the original decor, just made it like its new from the showroom (or better ). Lot's of room in these wide bodies.
The 310 has been patiently watching and is ready and eager for our first spring campout in a couple of weeks.
AIR #13
03-26-2016, 06:03 AM
#431
1966 26' Overlander
Woodstock
, Georgia
as usual fine work there Peter. Those are nice models, heavy as heck though.
03-26-2016, 09:35 AM
#432
Richmond
, Kentucky
Looks good Peter
I'm sure the 310 missed you....
03-27-2016, 12:05 PM
#433
Dazed and Confused
Hillsburgh
, Ontario
John and I are jealous as we had a Colorado low go through our area leaving almost 3/4" of ice on everything, including "The Mistress". A bunch of limbs down, including a number of trees down; lost power for a number of hours and internet/cable for days. It could be worst as our friends power is not back on yet after five days.=== No work done on our projects.
Good work Peter.
Cheers
Tony
03-27-2016, 01:40 PM
#434
Richmond
, Kentucky
Good work Peter.
Cheers
Tony
Hmm...I just finished 2-1/2 hours of mowing. I'm not sure whether I would prefer the ice or the constant mowing
03-27-2016, 02:01 PM
#435
Airstream Driver
1994 30' Excella
Austin
Easy for you to say, all you need to do is push a button and you have 76 degree shop to work in. We poor souls have to work in 75 degrees with sunny skys down here in the south.
But look what I am wasting my time on. This bumper got mangled badly, worse than the picture shows. Well here is the fix. I may be better off cutting my grass...
AIR #13
03-28-2016, 05:16 AM
#436
1966 26' Overlander
Woodstock
, Georgia
been 70+ here for awhile now, things blooming all over. But rain and amazingly thick pollen have kept me out of the trailer work. Luckily I did most of what I needed weeks ago, as soon as it got warm. Ready for 3 Airstream events in April...and one in May. Fun times.
03-28-2016, 10:21 AM
#437
Richmond
, Kentucky
More like 46 or 56 degree shop! I don't heat the shop any more than that during the winter. In the summer I just have 4 overhead fans the keep me cool.
Your repair looks good.
If you want to mow grass come up to Kentucky
03-28-2016, 10:28 AM
#438
Foothill Ranch
The grass is always greener....
03-28-2016, 11:00 AM
#439
Richmond
, Kentucky
Green not greener....
We get the right mix of rain and sun here such that you can sit on the porch and watch the grass grow...seems like about an inch a day
03-28-2016, 11:52 AM
#440
1999 34' Excella
Hillsboro
The grass is always more green on the other side of the fence.... but, sometimes it chokes your mower....
Peace and Blessings..
Channing
WBCCI# 30676
