Old 05-15-2025, 08:30 AM   #1321
LM782's Avatar
1985 34.5' Airstream 345
Lexington , Massachusetts
Welcom back!
Wow! That is a beautiful rig. Welcome back to being a MoHo owner. I'm sure you will get the mechanicals figured out soon enough. 70k is just broken in.
Luis
LM782 is offline   Reply With Quote
Old 05-15-2025, 11:09 AM   #1322
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Luis
Never say never This time a made it almost 3 years without a classic, which is a new record.
1991 300LE Classic Touring Coach
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 05-15-2025, 11:15 AM   #1323
Airstream Driver
1994 30' Excella
Images: 49
Finally got the airbags and finished installing them. For those curious about the 300LE rear suspension, here is a close up. No cut leaf springs, dog bone, no possibility for the bags flip. And yes the airbag carrier beam could also be dropped, after getting those massive Nuts cracked.
ID:	453264   Click image for larger version
AIR #13
Old 05-15-2025, 04:09 PM   #1324
Airstream Driver
1994 30' Excella
Images: 49
check valve at air compressor
If you have the original air compressor (mounted in a box underneath in the early 90"s models) and you have a mystery leak, you should look at the check valve right at the compressor. Some brilliant mind thought that aluminum would make a great check valve especially for tapered Threads
I found the same cracked valve in the 92 350LE.
AIR #13
Old 05-17-2025, 01:17 PM   #1325
Airstream Driver
1994 30' Excella
Images: 49
Put up wet and no maintenance for a decade!
Fixed the trans housing output shaft seal, it was pouring out. The engine rear seal needs to be done ,too. I am having the oil tested by Blackstone Laboratories before making any major decisions about the engine.
The fuel lines crossing over from the frame rail to the engine (4th picture) were about to go up in flames. I just don't get it how folks can just ignore such severe safety issues. I sure am glad that I didn't try to drive this rig the 90 miles from San Antonio to Austin.
The excellent body and interior make up for a lot of these mechanical and safety issues. But it should serve as a warning to potential classic buyers to not jump in some unknown 30 year old rig and drive across the country
ID:	453308   Click image for larger version
ID:	453310   Click image for larger version
AIR #13
Old 05-18-2025, 06:31 AM   #1326
Airstream Driver
1994 30' Excella
Images: 49
The oil filter tells its own story of neglect. Fortunately there is a heat shield with a clamp, because once I removed the clamp the filter just turned out easily by hand. Any guesses how old this filter is ...20 years ?
The space in front of my shop tells the story of the battle. So the tally is it took 4 days to get this coach roadworthy and thats only with a brake inspection and not some much needed brake maintenance work. Ok, Dirk (you know who you are), do you read me? Forget the dream of jumping in one of these rigs in somewhere USA and happily driving down the road .
ID:	453330   Click image for larger version
AIR #13
Old 05-20-2025, 11:40 PM   #1327
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Originally Posted by PeterH-350LE View Post
bubbles and a heavy duty rear suspension. Quite amazing and puzzling that they only used it on the 91/92 300's
Helllo - he's back. I wonder who will be the (very) lucky owner of this coach.
My 1991 250 had the standard air bag suspension set up.
If you look here: https://www.gm.com/content/dam/compa...-Motorhome.pdf
How does the 300 LE GVWR map into the chassis lengths and standard set up from Chevy when it lt left he factory. I'm curious as to why they would do that. I have a vague memory of a discussion about Airstream modifying suspensions in the hope of addressing shortfalls in the load capacity of the chassis. Something which clearly wasn't possible or strictly legit.
As a side note, my 250 (which did come out of the commercial division) had a VIN tag with a GVWR of 14500 lbs. I asked a few other 250 owners about this and everyone else had 12300 lbs. Again, very odd...Chevy did offer the higher load weighting as an option.
Boom Sounds is offline   Reply With Quote
Old 05-21-2025, 04:50 AM   #1328
Airstream Driver
1994 30' Excella
Images: 49
Amazing info (as usual), Nick! Except all of them sport the leaf spring set-up. The 91/92 300LE doesn't even exist in that line up. It obviously was dropped by aliens to completely mess us up, after we finally thought we had figured these rigs out. The GVWR is 14500, just like your 250, haha. I have to measure the wheel base to see if that is listed in your doc.
ID:	453398   Click image for larger version
AIR #13
Old 05-21-2025, 11:48 AM   #1329
Was it on the 178” chassis? Do you think it was Airstream or a prior owner modification? I would have thought it came out of GM as totally standard although there were some optional RPO codes for a heavier suspension from the factory and i’ve always pondered whether that is what happened to mine. One day, if I’m feeling flush I might pay GM for a build sheet breakdown from Website: https://www.gmheritagecenter.com to see if it tells me anything. Might be a waste of 50 bucks though
Old 05-21-2025, 12:03 PM   #1330
Airstream Driver
1994 30' Excella
Images: 49
Its the 208" chassis. I have seen pictures of 2 other 300's with the same Airbag setup. So its not some prior owner modifications, it came like that from GMC.
AIR #13
Old 05-21-2025, 01:57 PM   #1331
You can spend 5 bucks with Northstar Performance and get a RPO build sheet. I suspect it’s the same as GM. It would be interesting to see the build sheet and might inform what they used put together at the factory.
Old 05-21-2025, 02:35 PM   #1332
Airstream Driver
1994 30' Excella
Images: 49
Nick, I went to their site, but did not see any link for that kind of info. Can you enlighten me?
AIR #13
Old 05-21-2025, 02:38 PM   #1333
Airstream Driver
1994 30' Excella
Images: 49
In the meantime, I wrote Airstream about the 300LE models and the lack of info and the crossed out 350 Model number on the cover of the manual.
They were kind enough to reply right away with not much info, but here it is:
Dan Maul (Airstream)
May 21, 2025, 8:11 AM EDT
Hello,
Thank you for reaching out. That's a great find. I'm really not sure why the manual, the previous or original Owner may have lost of throw out the orig manual and picked up a 350 which would be almost identical.
The suspension may have been changed due to parts shortage, vendor changes, or testing different suspension. There's really no way to tell. We may have a few people that were here when it was built, but I'm sure they won't remember those kinds of details.
As far as production records, we would probably have the records of what and when a VIN was built, but not the details of what was in each unit other than what you've found on the website in archives. It may list out what was installed, but not why the change.
Dan
Dan Maul
Visitor Experience Coordinator
AIRSTREAM®
AIR #13
Old 05-23-2025, 11:36 AM   #1334
Here you go Peter https://store.northstarperformance.c...rpo-codes.html
For info, I’ve spoken to many 250 owners over the years and there was no specific manual for that unit either. We got a 350 series manual with a few extra loose pages from technical design which were 250 specific and set out the electrics and plumbing set up. The manual number was also crossed out and 250 added. That was it.
Old 05-23-2025, 04:28 PM   #1335
Airstream Driver
1994 30' Excella
Images: 49
A lot of items are 100 % transferable, but having a diagram of a completely different Airbag system is a bit over the top. Thanks for the link!
Cmadmaxman has pretty much convinced me that the Air systems on all classics are an aftermarket job. Who did the 300 version is still a mystery.
AIR #13
Old 05-24-2025, 12:38 AM   #1336
I agree, that matches my understanding as well. My hunch—especially since you’ve seen the same setup on other 300s—is that this was an Airstream modification specific to the 300 series. As for why they did it, that’s probably a detail lost to time.
The 250 is a bit of an oddball. There’s hardly any documentation aside from those loose pages I mentioned, a single A4 sheet listing options from Toscano RV, and a German-language promotional poster I picked up years ago—likely from the failed attempt to export diesel 250s to Europe.
From what I’ve been told by Airstream, many of the 250s were built by their commercial division, including models like the Aircoach shells and ambulances. The archivist confirmed that mine came through the commercial side of the factory, and I’ve always wondered if that explains its supposedly higher load rating.
I could be mistaken, but I don’t recall seeing much promotional material for the 300s either. It makes me think that both the 250 and 300 might have been special-order models, and perhaps your unusual setup is a result of it coming through the commercial division as well. You might want to reach out to Sam Martin, the archivist—she’s been very helpful in the past.
Either way, I think that’s a fantastic coach—great size, and I imagine it would do really well over here, especially with an LPG conversion. Propane is still much cheaper than petrol in most parts of Europe.
Old 06-01-2025, 10:13 AM   #1337
Airstream Driver
1994 30' Excella
Images: 49
a little generator maintenance. Thanks to Cmadmaxman for talking me into de carbonizing the heads/cylinders whilst I had it out and for guidance and specs!!
One of the head bolts was barely finger tight. Those OEM Onan parts sure are pricey, $420 for an OEM carb versus $60 for the knock-offs. I went with OEM on most parts.
AIR #13
Old 06-12-2025, 07:09 PM   #1338
Airstream Driver
1994 30' Excella
Images: 49
Generator all back together, the replacement made in china metal filter at the carb leaked, had to get rid of it. Did a test run, fired right up and its running smooth. Will install tomorrow
AIR #13
Old 06-12-2025, 07:13 PM   #1339
Airstream Driver
1994 30' Excella
Images: 49
Rear Centramatics arrived! 400-417 ready for the new Goodyear tires coming soon. Only the best!
AIR #13
Old 06-12-2025, 08:14 PM   #1340
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Looking good Peter, glad it all worked out. Nice to have a good running Genset!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 10:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 10:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 03:58 PM
