Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-21-2019, 09:55 AM   #701
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by bobmiller1 View Post
You got your work cut out for you, Regards, Bob
That's how we like it, Bob, don't we?
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 12-21-2019, 02:26 PM   #702
Airstream Driver
1994 30' Excella
Images: 49
we have awnings all around
AIR #13
Old 12-21-2019, 02:45 PM   #703
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Very nice!
martin300662 is offline   Reply With Quote
Old 12-22-2019, 12:54 PM   #704
Airstream Driver
1994 30' Excella
Images: 49
found three transfer switches. Could the third one be for the onboard inverter only powering some of the outlets?
ID:	358062   Click image for larger version
AIR #13
Old 12-23-2019, 12:50 PM   #705
Airstream Driver
1994 30' Excella
Images: 49
Here is a good one:
Generator didn't want to start, so I ran a line to a can and it started right up and supplied plenty of power to run both AC's
So, logic tells me not enough gas in tank to feed the 3/4 or so pickup tube. Even the transport driver had me add 5 gal, because he thought tank was empty.
Fuel gauge is a replacement and showed full.
So I went and got 10 gal and poured it in the tank. Oh no, drip drip drip. They didn't clamp down the inlet hoses and I am sure now, they did not connect the generator line or swapped it with the return line.
Now I have to get rid of another 70 gal of fuel and drop the tank. Yeah!
AIR #13
Old 12-23-2019, 02:38 PM   #706
Originally Posted by PeterH-Airstreamer View Post
Here is a good one:
Why not use a siphon hose to speed up the process....
1975 24' Argosy Motor Home
Old 12-23-2019, 09:15 PM   #707
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Undo fuel line on motor and power up fuel pump in the tank to push the fuel out. Have someone at the ignition key to control flow.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 12-23-2019, 09:42 PM   #708
Airstream Driver
1994 30' Excella
Images: 49
Cheers
Sidekick Tony
Now you are talking, fuel pump is on a switch already. Thanks and all the best for the holidays!
AIR #13
Old 12-24-2019, 08:31 AM   #709
Leave it to Tony to come up with an elegant solution
Old 12-24-2019, 08:55 AM   #710
Airstream Driver
1994 30' Excella
Images: 49
Yeah, Brad, sometimes he actually earns his nickname.
AIR #13
Old 12-24-2019, 09:15 AM   #711
That depends on which nickname. My guess is he's probably got a few nicknames that aren't printable......
Old 12-24-2019, 01:15 PM   #712
Airstream Driver
1994 30' Excella
Images: 49
Only you would know. I should have said "Honorable Title"
AIR #13
Old 12-24-2019, 09:18 PM   #713
Dazed and Confused
Isuzusweet's Avatar
I resemble that remark, and am proud.
Cheers
Sidekick Tony
PS, Merry Xmas all; heading to midnight mass with the DW, after a delicious Christmas Eve dinner with family and friends.
Old 12-25-2019, 07:34 PM   #714
Airstream Driver
1994 30' Excella
Images: 49
I posted this some time ago, but in case someone missed it, here it is again:
How to get your panel AC light back after upgrading to a three stage converter without the mysterious brown wire. Actually, I am using the adapter at 7.5V.
ID:	358200   Click image for larger version
AIR #13
Old 12-29-2019, 07:29 AM   #715
Are ya done yet.......?
Old 12-29-2019, 08:25 AM   #716
Airstream Driver
1994 30' Excella
Images: 49
Getting close, should be wrapping it up by the end of the month. In the meantime, I found this switch, I have never seen before. Could it be the autofill switch for the freshwater tank?
ID:	358303   Click image for larger version
AIR #13
Old 12-29-2019, 08:33 AM   #717
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
You are correct, but itís not a switch, itís a solenoid. If you upgrade to a 1/2Ē ID solenoid the tank will only take 5 minutes to fill instead of 30, Regards, Bob
bobmiller1 is online now   Reply With Quote
Old 12-29-2019, 08:39 AM   #718
That 350 has way to many bells and whistles!
The end of the month is only 2 days away........just sayin
Old 12-29-2019, 08:46 AM   #719
Airstream Driver
1994 30' Excella
Images: 49
Thanks, Bob!
Also found floor rot along the floor channel on the rear street side just forward of the fuel inlet. I checked all adjacent water lines and they appear to be fine. Must be an external issue related to the long awning draining down the side. Unless I have some toilet supply issue buried in the cabinet.
AIR #13
Old 12-29-2019, 10:23 AM   #720
Airstream Driver
1994 30' Excella
Images: 49
I didn't say which month
AIR #13
Need a new gear/sprocket for a Reese lector-jacket! Ribbler Towing, Tow Vehicles & Hitches 4 06-03-2013 11:45 AM
Vintage Airstream jacket eBay Watch Airstreams on eBay 0 02-09-2012 11:10 AM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 04:20 PM
motorhome jacket ALANSD Airstream Motorhome Forums 4 12-09-2002 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
