04-04-2017, 10:05 AM
#21
Foothill Ranch
I have a similar dent there too...
Rear wrap is available from Inland.. or so I thought...
Take off the rail by drilling out the rivets,
Get a suction cup on the panel and see if it will pop out.
Something like this...
http://www.harborfreight.com/pneumat...ler-69718.html
04-04-2017, 11:48 AM
#22
1982 34' Limited
1986 34.5' Airstream 345
Sioux Falls
, South Dakota
Bananawrap anyone?
Hey Keyair,
First, may I say that your rig fairly jumps off the page in all its glistening. What an amazing job you've done. I'm going to go back and look through the pics.
Thanks for this. I will check with Inland.
I really just want to get the banana wrap back in place and improve the dent enough to do that. Of course, I'd like to improve the dent a lot, but I'm not going to get my knickers in a twist if some dent is left.
I'm not sure how much I have to correct the dent in order for the bananawrap to fit back on there. Did you attempt this yet? Do you think we can replace the bananawrap without too much trouble, no matter what happens with the dent? Or do you think the dent is the limiting factor here? I ask because we're planning a long road trip and if I can't do it, then I have to budget time for a service stop.
I'm happy to get the pneumatic tool. I'm sure it would come in handy for cranial-anal inversions, as my chiropractor calls them.
Thanks!
Jenniflow
04-04-2017, 01:22 PM
#23
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Originally Posted by Jenniflow
Hey Keyair,
Thanks!
Jenniflow
Did you collect all the parts for the broken banana wrap? The ABS is repairable if most of it is there.
I am fast coming to the opinion that they are not all the same across models, as the replacement rear I got for Peanut was different from the original and since we have found the two new fronts are different from Peanuts original.
I have lost track of how many non-fitting new/replaced old, front and rear banana wraps Brad has tucked away at his place!
04-04-2017, 05:42 PM
#24
1982 34' Limited
Sioux Falls
, South Dakota
ABS repair
Thanks Martin300662,
Now I am definitely going to check on the ABS repair option. I didn't realize how much variation there was.
I do have a couple of pieces that fit in the palm of my hand. I'm hoping they are all there were. And of course, I have the big piece. I'm not with the coach now but when I get there I will see if they make a whole.
What kind of tradesperson does this kind of ABS repair?
Thanks!
sent from my hipflask
04-05-2017, 12:22 AM
#25
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Thanks!
ABS can be glued (either using as special adhesive or using MEK to dissolve ABS pelts) and can be bought in sheets to repair holes (a little heat and it bends), and if done by a good bodywork guy can look as good as new (see what Ernie has managed to achieve on Peanut http://www.airforums.com/forums/f310...on-148273.html) or, if you aren't that worried about it looking perfect, why not have a go yourself?
04-05-2017, 12:30 PM
#26
1982 34' Limited
Sioux Falls
, South Dakota
ABS repair
Oh, I wish! Sounds tempting though, I could try it, but I'm too busy screwing up other projects I'm working on.
But it's great to know that someone competent can probably repair this one because I do believe I have enough of the pieces.
Will post pics when we've got it done!
thanks.
04-05-2017, 12:33 PM
#27
1982 34' Limited
Sioux Falls
, South Dakota
I just went to check out the Peanut thread and it is great! Will read more as I go along.
