Old 07-09-2018, 08:21 AM   #41
Kaufn Nailer's Avatar
1994 36' Classic 36
Lancaster , California
Nice Rig!
Was the roof white from the factory or painted after???
I believe that it came from the factory coated in white.
Kaufn Nailer is offline   Reply With Quote
Old 07-09-2018, 09:19 AM   #42
1995 36' Classic 36
Ludington , Michigan
Itís factory. Both my 360s (94 and 95) and every other one Iíve seen are white. Seems to be a pretty durable coating. Ever in strong desert sun.
Kota is offline   Reply With Quote
Old 07-12-2018, 10:29 AM   #43
Mike1997's Avatar
1998 36' Land Yacht Widebody
Reidsville , Georgia
Images: 14
The washer/dryer is located to the right of the frig, directly on top of the furnace, about half way over the right rear wheel well. Its at same height as the double closet which is also over the wheel well with drawers below.
Over top of the washer is a deep storage cabinet. Its also within both doors of the bathroom so can be closed off if needed. Will look for a floor plan to share too.
Great looking Airstream!!!
Mike1997 is offline   Reply With Quote
Old 07-12-2018, 04:08 PM   #44
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Originally Posted by FishByFly View Post
Donít forget to raise those tension arms on the awning. You maybe doing just a test pull but FYI.
What are "tension arms"? Never heard that term before in regards to a zip dee awning? Wondering if I'm missing something?
mayco is offline   Reply With Quote
Old 07-12-2018, 04:26 PM   #45
2007 22' International CCD
Also known as "Rafter Arms" in some discussions...the ones with the hooks on the end that hold the fabric out and make up the top of the 'triangle' of metal arms on the end of the awnings...
Home Sweet Home deauxrite Upholstery, Blinds, Walls & Interior Finishes 7 11-19-2017 10:23 AM
Taking a two week trip Drake1949 2005 and newer - Bambi all models 4 07-24-2016 04:51 PM
Home away from home :: 2003 Airstream Safari fman88 Airstream Registry Discussions 0 09-14-2011 05:54 PM
Our Home Away From Home Bobz Hog 1965 - 1969 Overlander 34 09-05-2009 11:24 PM
A home away from home drjudy Member Introductions 8 10-31-2007 04:58 PM
