Old 04-09-2017, 09:45 PM   #1
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Stripe removal?
Does anyone have a suggestion as to how to remove the long side stripes that we have on our classics? The Jasco brand stripper that I've tried barely seems to touch the stripes and their adhesive backing. Not sure if this is another case of the environmentalists taking all the punch out of a product. I seem to recall that the stuff was a lot nastier to work with several years ago. Any suggestions are much appreciated.
streamquest is offline   Reply With Quote
Old 04-09-2017, 10:10 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Charly, Is yours paint or decal ? If it's decal are you using what looks like a round eraser wheel on a power tool ? Look up a PT280-THUG, this is what I sell the guys in the body shops. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-09-2017, 11:59 PM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Google it with airforums in the title. I think there are other posts on this topic. Steve (keyair) might have posted one.
Boom Sounds is offline   Reply With Quote
Old 04-10-2017, 03:53 AM   #4
2017 23' Flying Cloud
2016 Interstate Lounge Ext
New England , Ontario
heating should work, which would loosen the adhesive but the stripe might disintegrate into small flakes and mush up with adhesive.
Use heat liberally and suing plastic putty knife it should work.
EdwardCharet is offline   Reply With Quote
Old 04-10-2017, 04:55 AM   #5
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
If you heat it, avoid a torch, you can warp the skin. Use a good heat gun
WayneG is offline   Reply With Quote
Old 04-10-2017, 05:46 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I did this twice. Both times I had to sand it and then stripe over it. You don't see the stripe underneath if its smooth. On one I had the stripe was painted on and it was awful.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-10-2017, 08:12 AM   #7
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Try one of these: 3M Stripe Off Wheel 07498, 3/8" Mandrel, 4" Diameter x 5/8" Width, Beige. They are sold on Amazon. I used them all the time to remove stickers, number decals, strips, etc. from my race cars. Works great. Do not heat before you use it or it will just smear.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 04-10-2017, 08:16 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I've got a 93 Classic. Removing the decal sounds like work, The stripes are OK except for some crazing. Anybody know a paint that will match the stripe color? There is/was also a thin stripe in the middle. Can anyone tell me what color it was?
I would love to hear more about what others did after removal. Photos even better.
Old 04-10-2017, 11:11 AM   #9
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
Yes, It work best when some heat was applied.
The world is a book and those who do not travel read only one page. St. Augustine
arden_dean is offline   Reply With Quote
Old 04-10-2017, 05:09 PM   #10
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Use steam, plenty of heat to loosen the decal and then pull while hitting it with more steam. If you keep the temperature up the adhesive will come off with it too.
sgschwend is offline   Reply With Quote
Old 04-11-2017, 11:47 AM   #11
Kreimer's Avatar
1965 22' Safari
1987 34.5' Airstream 345
Kansas city , Missouri
ID:	283168 This is what I used. It removed decal and the vinyl replacement stripe. Took about three applications. Just give it time to work and tape off anything you want to not have clear coat removed.
Kreimer is offline   Reply With Quote
Old 04-11-2017, 01:10 PM   #12
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by Kreimer View Post
Attachment 283168 This is what I used. It removed decal and the vinyl replacement stripe. Took about three applications. Just give it time to work and tape off anything you want to not have clear coat removed.
More toxic than most other stripers. Use outside. Wear gloves, long sleeves and eye protection. Did not know it works on decals, but one of the few stripers that is effective on clear coat.
Old 04-11-2017, 02:17 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Citri strip and a plastic scraper will work. It takes 3 applications on a small area atatime under ideal conditions. If it is too hot it just bakes on and does not cut.
Bill M. is online now   Reply With Quote
Old 04-11-2017, 04:13 PM   #14
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Yep! that's what I used. Tried about 4 other thing before I found this. Save yourself some time and money. Use the good stuff.
Gregsch is offline   Reply With Quote
Old 04-11-2017, 09:36 PM   #15
1936 20' Clipper
1947 22' Liner
Curtis Wright
Thanks to all for your suggestions. I think I'll give the Aircraft stripper the first shot. It sounds like the most aggressive option. I will report back with the results.
Old 04-24-2017, 04:42 PM   #16
1936 20' Clipper
1947 22' Liner
Curtis Wright
Just wanted to follow up with my stripe removal results....
Thanks Kreimer! This is the stuff to use for sure!!!! Just tried it out and it kicks butt. I had a good feeling about it as soon as I opened the can. The noxious fumes are the giveaway. I wonder how long it will take for the Green Police to pull it off the market, as has happened with so many other really effective products.
Definitely want to cover anything that you don't want to have eaten up! Forget all the rest, this is the magic bullet.
Aircraft Paint Remover rules!
Old 04-24-2017, 05:53 PM   #17
Kreimer's Avatar
1965 22' Safari
Glad it works! If you shake the can really well the fumes seemed to be not as terrible to me.
Old 07-13-2018, 04:22 PM   #18
1993 31' Legacy 30
Saskatoon , Saskatchewan
I have a 1993 LY legacy Motorhome. I have a quote for $2300 to recover the entire
Stripe with white the apply a second stripe with colour of choice. No removal of original stripe. They assure me the second layer will cover the original blemishes . They are a reputable shop and came up with several recommendations. What do people think, am I wasting my money?
Streamerden is offline   Reply With Quote
Old 07-13-2018, 04:42 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I'm re-doing the 1/2" 'chrome' belt molding, with marine vinyl 3M tape . (Above the Classic Oval) All the shiny left years ago, but the surface is still smooth & intact.
Getting Premium Blue reflective, 1/2" wide, 150' roll $61.25. Ordered it today.
Have used it on boat with very good results, tough stuff.
Obrigado, hora de descansar.
Tahawus
Old 07-13-2018, 04:52 PM   #20
Buy a roll and practice...it's a definite DIY job. Thats a lot of $$ for a fairly easy job. 👍
Tahawus
Old stripe removal Stonew98 Clearcoat, Exterior Paint & Trim 3 11-02-2012 09:13 AM
Vinyl Stripe Removal and Replacement dbj216 Clearcoat, Exterior Paint & Trim 2 06-08-2012 04:21 AM
Rally Stripe Removal BeBop Cleaning, Stripping & Polishing 0 04-21-2010 08:22 AM
Stripe removal. Cauuck Clearcoat, Exterior Paint & Trim 1 08-19-2008 09:51 PM
Blue Belly stripe removal Easyriser Clearcoat, Exterior Paint & Trim 2 07-14-2007 12:36 PM
