Old 05-04-2025, 02:12 PM   #1
1989 34.5' Airstream 345
Kingsland , Texas
Steering Wheel Removal
Finally got my 89 345 back on the road! Actually been several months and have 3000+ miles on it!
Working through several issues, but one of my bigger ones is that the horn doesnt work. There is a bad connection down under the steering wheel. I can twist the wire and it sometimes closes the circuit, but I cant get it to work all the time.
So..... Trying to pull the steering wheel. I got the ring and nut off, but nothing I do will get the wheel off. Anyone gotten this off before? And now I may need a replacement hub that the steering wheel attaches too as well. I put a pulley puller on there and it just bent the hub.
thanks,
Aaron
Airdelroy is offline   Reply With Quote
Old 05-06-2025, 06:51 PM   #2
Kingsland , Texas
I was able to get both horns working on the roof. There is an adjustment screw once you open up the back cover that I loosened until the horn blew.
Im sure the neighbors love me now.....
Still unable to get the steering wheel off though. I did find the relay, so may wire up extra button somewhere. Not ideal, but will work until I can get in there to clean the contact.
Aaron
Old 06-15-2025, 08:31 AM   #3
Kingsland , Texas
Just an update here. I guess I wasnt thinking clearly when I tried this. I went back for a second try and determined that I should not pull on the base of the collar, but I sohuld pull on the bolts near the top of the collar. Once I put the puller there, it came off without issue.
Took apart the contact mechanism and cleaned it all up. Horn works now!
I even got on the roof and got the second horn to start working as well.
Aaron
Old 06-16-2025, 04:53 AM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Amazing…….the roof horn is the best ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 06-17-2025, 09:52 AM   #5
"Cloudsplitter"
Horns....
We LOVE horns...
I’m an AS owner, and I'm really good at fixing things that aren't broken.
ROBERT CROSS is online now   Reply With Quote
Steering Wheel Off Center Michigander Land Yacht/Legacy Motorhomes 7 04-04-2013 07:45 PM
Steering Wheel Upgrade? RAG Land Yacht/Legacy Motorhomes 2 05-09-2012 08:39 AM
steering wheel re-wrap? str8strm General Motorhome Topics 5 04-14-2009 09:17 AM
Steering Wheel replacement joewinfield Classic Motorhomes 19 09-21-2008 07:17 AM
GM option--4 wheel steering Kistler Our Community 4 01-08-2003 02:30 AM
