Old 03-12-2018, 03:25 PM   #1
Kreimer's Avatar
1965 22' Safari
1987 34.5' Airstream 345
Kansas city , Missouri
Spot control
Does anyone have, or know where I can get one of these? Or more specific the connections behind the plate. OR have nay idea how to replace it with a new unit using the existing spot light?
Kreimer is offline   Reply With Quote
Old 03-12-2018, 03:25 PM   #2
Kreimer's Avatar
1965 22' Safari
Originally Posted by kreimer View Post
does anyone have, or know where i can get one of these? Or more specific the connections behind the plate. Or have nay idea how to replace it with a new unit using the existing spot light?
Old 03-12-2018, 04:44 PM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Someone on her had one going some time ago. Have a search on the forums. If it helps, mine works so I can show wiring etc
Boom Sounds is offline   Reply With Quote
Old 03-12-2018, 05:15 PM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My switch has gone bad also. Intermittent. As everything else electrically related on our beasts, it's a total cluster inside the wall. Haven't really tried yet to see what can be done or if replacement is an option, the only thing I think I know is that it IS the switch. I can get it to work intermittently. Would be nice to be able to retrofit a new switch into the system.
mayco is offline   Reply With Quote
Old 03-13-2018, 05:43 AM   #5
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Did so on my 325LE check out the post with the Marinco unit install "It's Never Done" used the switch from the 325LE for the bad one in the 370LE. Regards, Bob
bobmiller1 is offline   Reply With Quote
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
soft spot repair stellablu Repairing/Replacing Floor &/or Frame 2 08-08-2003 03:18 PM
can you spot my trailer? john hd Our Community 17 11-10-2002 05:33 PM
spot-polishing....? Chuck Cleaning, Stripping & Polishing 1 07-19-2002 08:54 AM
