Old 12-20-2018, 10:58 PM   #1
1981 28' Airstream 280
Mabank , Texas
Skinner Electric Valves
Good evening and Happy Holidays y'all,
I have looked high and low on my 280 Excella and I can not find an air compressor anywhere on this beastie. However, there are two little doohickeys called Skinner Electric Valves, one on each side of the accumulator tank and I am wondering if these could have replaced the original air compressor. Or are these valves simply in the compressor hierarchy. Help me please. What do I have or not have here.
ID:	330076   Click image for larger version
ID:	330078   Click image for larger version
yelsewkrats is offline   Reply With Quote
Old 12-21-2018, 01:29 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The skinner valves shut off the air flow to and from the air spring on each side when the ignition is off to help prevent bleed down. The compressor is in the exterior rear storage compartment. It may be behind a false wall in the compartment. If you drain the air tank and turn the ignition key to "on" but don't start the engine you should be able to hear the compressor at the rear of the coach.
Cheers, Dan
~ Margaret Thatcher ~
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Electric Dump Valves J R Vaughan General Repair Forum 3 08-20-2012 10:36 AM
Electric Waste Valves wasagachris Waste Systems, Tanks & Totes 8 08-20-2010 12:57 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
