To my knowledge, nobody has done that.
Keep in mind
1, the shower pan and wall are ABS plastic, can't get too hot
2, you'll have a lot of steam condensing on the aluminum walls and cieling outside the shower
Sounds cool though, link to the radiator?
1983 Airstream 310 Class A Motorhome
-Rob
1987 32.5' Airstream 325
Windsor
, Ontario
I plan on covering the interior of the shower with cedar (a parted out airstream closet would be perfect.) I don’t see the floor getting any direct heat.
Radiant panel would be dry heat so I thought to April the air with a spray bottle ( not a true sauna I suppose)
Can vent the heat out of the unit from my bedroom fan.
