Old 05-22-2017, 06:12 AM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Shocking
I have been searching around for the best deal on a set of new shocks for my 83 310 (82 chassis) and came across this site.......
http://www.eshocks.com/bil_veh.asp?M...tein&SubChar=Q
However they list the years for the steering damper as 84-00 as opposed to the shocks 73-00 (you have to click on add to cart to see the steering damper years). I do have a steering damper in my 310 and am 90% sure that this will work, but need someone who knows better to say, yay or nay. I was this close to hitting submit when I noticed the years difference.
Also, decent prices for these? What do you think?
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 05-22-2017, 07:05 AM   #2
Tony, I'm not seeing the 84-00 that you're mentioning. All I see is the 73-00 for the shocks and the steering damper.
I can't believe there is any difference between 73 and 84. Monroe lists the same damper for 75 and 83.
Old 05-22-2017, 07:31 AM   #3
Dazed and Confused
Isuzusweet's Avatar
Yeah, it list 73-00 in the first page, but if you click on add to cart, the years for the damper change to 84-00. I'm thinking it has to be a typo but wanted to check.
What do you think of the prices Brad? They are Bilsteins.
Cheers
Tony
Old 05-22-2017, 07:52 AM   #4
Cheers
Tony
Gotta be a typo.
Prices probably aren't bad. I opted for Monroe shocks and damper because I had no idea when (if ever) I would be driving my Argosy. I figure once I actually do use it for a while I can always switch over to Bilsteins
As an aside, on my old 84 310 I had installed Bilstein shocks and one day while looking at the front suspension I noticed that the right front shock was hanging down. Turns out the rod had snapped where it bolts to the lower control arm. It was at that point I noticed just how much the front springs sagged. I told the new owner to replace the front springs before doing any more driving.
Old 05-22-2017, 08:07 AM   #5
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I used the same company when i bought the front and rear shocks for the 325LE....I also bought a Bilstein front steering damper from them at the same time....let me know if you need the part numbers....or you can just call him. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 05-22-2017, 10:40 AM   #6
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I used the same company about ten years ago and they were the cheapest then. I think they sold me a bulk deal all four shocks and the dampener. Parts should reference a P37 Motorhome, which is the correct specification for our Chevy chassis.
My 1991 coach order as follows
2 B46-1173-H3 73-00 P1500, P2500, P3500, P10, P20, P30, P32, P37 Motorhome Class A Bilstein Heavy Duty Front Shock $78.65 $157.30
2 B46-1587-H1 73-00 P1500, P2500, P3500, P10, P20, P30, P32, P37 Motorhome Class A Bilstein Heavy Duty Rear Shock $78.65 $157.30
1 BE3-2645-H0 84-00 P1500, P2500, P3500, P10, P20, P30, P32, P37 Motorhome Class A Steering Damper $78.65 $78.65
Boom Sounds is offline   Reply With Quote
A SHOCKING new development tx-lawman General Motorhome Topics 17 10-01-2006 10:35 PM
Need shocking advise! eikel1we Shocks 9 10-01-2006 02:30 PM
A Shocking Experience dwvh2o Electrical - Systems, Generators, Batteries & Solar 5 07-03-2006 07:23 AM
Shocking Touch fastrob Electrical - Systems, Generators, Batteries & Solar 27 10-16-2005 05:04 AM
SHOCKing question...... Safari Tim Shocks 27 05-17-2005 07:50 AM
