Old 05-09-2018, 02:48 AM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Roof Coatings
Trying to come up with a solution to:
1) cover the hail damage inflicted on the AS roof
2) reduce heat build-up in summer sun
3) ensure there's some additional sealing
Called the 2 companies that advertise their roof coatings. The least expensive was better than $4200 & the other was on the N side of $5K. Would prefer not to spend that kind of money.
Trailer folks offer a couple of options, but the product recommended in 1 case has been discontinued. Both suppliers apparently have been absorbed by GAF and I'll be calling them for recommendations.
Anyone covered their roof? What product did you use? Regrets?
wimpy is offline   Reply With Quote
Old 05-09-2018, 05:02 AM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I stripped the roof of the 370LE down to the original aluminum then applied 4 Coates of exposy primer then 3 Coates of glossy white paint. The primer filled all the pin hole leaks from the mis drills the factory had made, I used self leveling siliflex for the larger gaps. Regards,Bob
bobmiller1 is offline   Reply With Quote
Old 05-09-2018, 06:20 AM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Bus-Kote 2150 by Hy-Tech Sales (http://www.hytechsales.com/prod2150.html).
I was up on Bella's roof yesterday and after 2 years still looks perfect, as well as drastically dropping the heat absorbed even in direct sun-light.
martin300662 is offline   Reply With Quote
Old 05-09-2018, 06:56 AM   #4
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I've gone for this stuff in grey. We should have a competition to see which lasts longest. What I do know is that it will give me a good few years protection up top.
http://www.epdmliquid.co.uk/buy-liqu....gJMQuFyw.dpbs
I was going to use it in conjunction with this, but have heard mixed reports.
http://www.eternabond.com/AlumiBond-p/rv-as.htm
I'll ask be using the Sika 512 Sealant/Adhesive. I think it has another code in the states.
https://www.uksealants.co.uk/sikafle...-adhesive.html
Nick
Boom Sounds is offline   Reply With Quote
Old 05-09-2018, 06:58 AM   #5
A W Warn's Avatar
Two Places , Sticks & Bricks
When you originally applied this product, how did you prep the roof? (did you remove existing coating, air conditioner, sewer vent covers, fan curbs) My Excella's existing white paint on the roof is almost gone, see through thin, so I'm looking for options for re-coating.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 05-09-2018, 07:00 AM   #6
+1 on Bus Kote.
If you are willing to put in the sweat equity, it'll cost you about a hundred bucks. My blog post on my job here, and yes, it really does help with heat rejection.
Edit: The comment above inserted ahead of this one as I was typing. The instructions for my job are in the blog post linked above. I did not follow the manufacturer's own instructions, at the manufacturer's recommendation. I skipped the clear coat, and I'm very glad that I did because I've since freshened it up in the manner they recommended.
Old 05-09-2018, 07:26 AM   #7
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Anything loose was sanded, and all joints re-sealed, then applied - it was messy and I am glad I paid someone to do it and was watching for afar!
I also missed the flex-clear sealer and so the finish is satin/non-shiny and does hold 'dirt' making cleaning a little more time consuming.
Old 05-09-2018, 01:07 PM   #8
Brand?
Originally Posted by bobmiller1 View Post
applied 4 Coates of epoxy primer then 3 Coates of glossy white paint. The primer filled all the pin hole leaks from the mis drills the factory had made, I used self leveling siliflex for the larger gaps. Regards,Bob
Stupid questions, could you expand on this? Danke!
Whose epoxy primer...what kind of white paint?
Also, where did you do the cut-off for the sides & front & back?
Old 05-09-2018, 02:30 PM   #9
https://lasmotorhomes.com/airstream/
Vinyl Flooring Coatings/Finishes/Polishes cbrittan Floor Finishes 0 02-13-2017 01:12 PM
Coatings - Cor15 Bed Liner sir_tob General Repair Forum 1 05-31-2016 08:09 PM
Hy-Tech coatings, for AS roof? cwf Roof 33 11-12-2015 04:22 AM
Rust Coatings-Help? budal General Repair Forum 7 06-07-2009 04:55 PM
