Probably a $20 to $30 part and simple install. Drop section of driveshaft, press off old bearing, press on new and reinstall driveshaft.
Cheers, Dan
________________________________________
"Socialist governments traditionally do make a financial mess. They always run out of other people's money. It's quite a characteristic of them."
~ Margaret Thatcher ~
Hey,
Yah about 30-45 bucks for parts, probably run you about 150.00 total. It should also come with a new rubber isolator. Not a huge deal, they don't really wear out. But as long as your going new, do both. Check those u joints too. If you need a carrier bearing, u joints may not be to far behind as far as failure goes. That rear one is the most prevalent one
AS got little u joints in my opinion. I got 2 spares ust in case. Good luck. DJ
