Old 09-03-2019, 06:17 PM   #1
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sioux Falls , South Dakota
Send a message via Skype™ to Jenniflow
Replacing carrier bearing
Hey folks, we’re getting back in the saddle soon to take the Ole Gal down to Baja but come to find out we need a new carrier bearing.
We can feel the rhythmic binding when we drive at low speeds. Which is all we dare drive.
It’s at a mechanic in Fallon.
Is this a difficult or expensive job? Are parts an issue? I didn’t find much about it on the forum.
Thanks!
sent from my hipflask
Jenniflow is offline   Reply With Quote
Old 09-03-2019, 09:26 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Probably a $20 to $30 part and simple install. Drop section of driveshaft, press off old bearing, press on new and reinstall driveshaft.
Cheers, Dan
~ Margaret Thatcher ~
Old 09-03-2019, 10:09 PM   #3
Jenniflow's Avatar
1982 34' Limited
Another $20 part
That is great to know, thanks so much!
Old 09-24-2019, 07:53 PM   #4
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
Yah about 30-45 bucks for parts, probably run you about 150.00 total. It should also come with a new rubber isolator. Not a huge deal, they don't really wear out. But as long as your going new, do both. Check those u joints too. If you need a carrier bearing, u joints may not be to far behind as far as failure goes. That rear one is the most prevalent one
AS got little u joints in my opinion. I got 2 spares ust in case. Good luck. DJ
davejay is offline   Reply With Quote
Bearing Buddy Bearing Protectors Ron A Wheels, Hubs & Bearings 23 05-19-2015 06:48 AM
Carrier bearing lube mayco Classic Motorhomes 6 03-22-2015 08:35 PM
Carrier bearing help Waipio Rim Mechanics Corner - Engines, Transmission & More... 6 07-07-2010 01:50 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
Replacing coleman AC with Carrier low profile MS325 Classic Motorhomes 11 11-10-2006 10:53 AM
