Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-30-2020, 08:47 PM   #1
Replacement Hood / Engine Cover Offset Cam Latch
One of the hood latch cams rattled off on my 1983 310 and the threading for the screw was all stripped out on both latch assemblies. I read a post about tapping the barrels for a wider screw and just my luck, my tap broke off when it bottomed out. While attempting to extract the tap, I trashed the barrel, which is made of weak pot metal. I looked all around and couldn't find a good replacement for the hood latches. I tried a few cheapo sets from amazon (Camco and "RV Designer Collection") and neither was the right length and both were very poorly made. I did find a post here from a long ago that mentioned a company called Southco made the original latches with a link to a dead website. I searched Southco and found their new website and was able to track down exact replacements for our old rigs!! They are very well made and feel like they will last as long or longer than the originals. They set me back $38.83 including shipping.
Here are the part numbers:
Cam Lock Latches
SKU: CM-1-3C109-1C
Cam Lock Cam, Steel, Zinc plated
SKU: CM-C614
And here is their website:
https://southco.com/en_us_int/
I'm not sure what years they are compatible with, but if you have the metal thumb latches that turn 90 degrees to latch your hood, these should be them.
78703TX is offline   Reply With Quote
Old 07-31-2020, 12:12 PM   #2
1982 31' Airstream 310
Henniker , New Hampshire
Try McMater-Carr
https://www.mcmaster.com/cam-latches/opens-with~handle/
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 07-31-2020, 09:38 PM   #3
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Cam Lock Latches
SKU: CM-1-3C109-1C
SKU: CM-C614
nice detective work! half the fun of owning one of these Classic Airstreams.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 08-01-2020, 04:50 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Certainly worth adding the 'classic motorhome' sticky thread so all the info on replacement parts is in one place.
martin300662 is offline   Reply With Quote
Old 08-03-2020, 08:02 AM   #5
Magnet18's Avatar
Churubusco , Indiana
That's great, thanks for sharing!!
Second that this should be added to the sticky
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
suggestions sought for Dash-cam & rearview cam WherryWillie Electronics & Connectivity 0 03-14-2019 02:02 PM
Engine hood Captain Paul Land Yacht/Legacy Motorhomes 2 11-05-2017 10:52 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 01:49 PM
5.3L chev engine with tow/rv cam replacement. carl2591 Towing, Tow Vehicles & Hitches 26 12-29-2012 05:06 PM
Hood latch nickglase Classic Motorhomes 4 03-02-2007 06:13 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
