Old 02-05-2021, 03:46 PM   #1
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Replacement axle/wheel covers???
Does anybody have a ssource for obtaining replacement axel covers for these classic motorhomes? I need all of them. The two 5 lug center caps and rings, and four 10 lug rear and tag center caps and rings. Any ideas are appreciated!
Kenneth
1987_345 is offline   Reply With Quote
Old 02-05-2021, 04:37 PM   #2
Magnet18's Avatar
Churubusco , Indiana
Might be able to find parts for a normal p30 wheel, 19.5"
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 02-24-2021, 03:10 PM   #3
Kenneth
1987_345's Avatar
Waxahachie , Texas
Found it!!!!!
Ok, for once I get to post a solution. I actually found near perfect center cap replacements on ebay. They are one piece instead of two but made of solid polished stainless steel. The vendor usually sells them with rim covers , but was willing to sell what I needed for around $200. I got all four rear ten lug center caps, the two 5 lug front caps, and 50 1 1/16" lug caps as well. The lug holes were a little larger than what I have, but I turned the cap in either direction to take out the slack and it centered up fine.
The description listed on Ebay was for a "19.5" Chevy GMC P30 Dually Wheel Covers 10 lug rear 5 lug front new bolt on" and the seller was "the_hubcap_king" You may want to contact him before ordering to make sure he knows you don't want the rim covers.
Good Luck, Kenneth
Old 02-24-2021, 04:00 PM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Great info.....thanks for posting ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Custom Axle Covers and Lug Nut Covers Constantin Classic Motorhomes 2 02-24-2021 07:46 PM
can you run a 16" wheel with a 15" wheel on the same axle. 80Ram Airstream Motorhome Forums 33 04-23-2020 06:50 AM
Wheel chock locks and wheel covers MaineStreamer On The Road... 30 01-04-2015 11:52 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
