Old 07-29-2018, 09:31 PM   #1
jkaftan's Avatar
1965 26' Overlander
1983 30' Airstream 300
Syracuse , New York
Rebuilding Driver and Passenger Windows
I have a 300 and the seals around the driver's window are shot and it is leaking. I need to fix this before the mold sets in.
I'm not sure where to start. Can anyone point me in the right direction?
John
jkaftan is offline   Reply With Quote
Old 07-30-2018, 06:52 AM   #2
Magnet18's Avatar
Churubusco , Indiana
+1
My passenger side window won't line up with the seals quite right and leaks under certian conditions
Following this thread
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 07-30-2018, 06:57 AM   #3
Originally Posted by Magnet18 View Post
+1
For materials start at post 137.
There are a lot of threads covering installation. If you have trouble finding them let me know and I'll try and point out a couple.
Old 07-30-2018, 10:04 AM   #4
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
+1
I had this problem after replacing the "fuzzy schlegel" stuff that the windows ride in. A tech at the Airstream factory went after them with a hammer and a wood shim and had everything lined up in about a half hour. Sadly I was not able to watch him work, just saw the tools that he took in with him.
Waipio Rim is offline   Reply With Quote
Old 07-30-2018, 10:56 AM   #5
Ran into the same issues while replacing the seals in Peanut. Lots of tweaking and adjusting of the cockpit window frames were required. The passenger side was in exceptionally bad condition. Several days were spent trying to work through the problems.
The biggest problem boiled down to the fact that the curve of the glass is different than the curve of the window frame/shell.
Old 07-30-2018, 11:18 AM   #6
Magnet18's Avatar
A wooden wedge and a hammer, guess it's a pretty straightforward process
-Rob
Old 07-30-2018, 12:45 PM   #7
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Somebody hasn't heard of the Airstream Gods.........somebody is going to find out what they're like.
Stay tuned.
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 07-30-2018, 01:08 PM   #8
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Yes......let me know how you make out with that....,Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 07-30-2018, 01:50 PM   #9
Actually we used a steel block....
Old 07-31-2018, 10:09 AM   #10
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Here is an old thread from us old timers who had classics years ago. The one thing I will always remember about replacing all my window seals is meeting my orthopedic surgeon. The classic is long gone but I still use the same orthopedic surgeon.
http://www.airforums.com/forums/f311...all-18806.html
Chaplain Kent
Forest River Forester 2501TS
Chaplain Kent is offline   Reply With Quote
Sun shade pull down for side driver and passenger side. Lford Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 10-22-2018 08:24 PM
Driver and front passenger step AirRiggie Airstream Motorhome Forums 0 06-12-2017 01:25 AM
1979 Excella Driver/Passenger windows RosiesGuy Windows & Screens 0 05-30-2015 07:45 PM
345 motorhome passenger and driver vinyl seals raveson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-11-2006 04:28 PM
Driver/passenger legroom/Argosy MH? pepepepe Airstream Motorhome Forums 4 01-01-2003 06:24 PM
