Old 03-21-2017, 05:28 PM   #1
1969 31' Sovereign
1982 28' Airstream 280
Edmonton , Alberta
Radiator support bushings
Im overhauling my 1982 280 turbo diesel and have the front end opened right up. After getting the rad re-cored $650, I've hit a brick wall trying to locate new rad bushings/cushions. Has anyone else replaced theirs yet? Gmc/ chev have discontinued this and what seems like a basic component has me stumped. Any help for what looks like might work would be appreciated
Swillv8 is offline   Reply With Quote
Old 03-21-2017, 05:48 PM   #2
I ran into the same problem with the vertical mounted radiator in my 74 Argosy. If your radiator is mounted vertically between the frame rails then as you've already found those pads are no longer available.
I ended up fabricating custom rubber pads. If you look at post 92 in the link you'll see what I did to solve the problem. They worked out very well and the radiator is sitting at the correct height although I think I did add a couple of washers to shim it just a little higher.
Post 835 at this link shows the radiator installed.
Old 03-21-2017, 06:23 PM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The rubber/polyurethane bushings are still available in all shapes and sizes.....PM me if you want the info. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 03-23-2017, 12:57 PM   #4
81 MexCella's Avatar
Kelseyville , California
I just installed mine yesterday and was able to reuse the original pads.
ID:	281944   Click image for larger version
"Electra"
1981 Airstream Excella 28' Turbo Diesel
Northern California
81 MexCella is offline   Reply With Quote
Old 03-29-2017, 12:19 PM   #5
1969 31' Sovereign
Edmonton , Alberta
Still have not been able to source these out yet
Old 03-29-2017, 05:08 PM   #6
bobmiller1's Avatar
What seems to be the problem ??? How about a couple of pictures.
Time for new Bushings. Where to Purchase them? John H. Airstream Motorhome Forums 6 06-13-2011 04:30 PM
P30 swaybar bushings for 81 Excella 280 silverback Classic Motorhomes 12 09-16-2009 08:01 PM
1965 Caravel door bushings and pin... VintageTin Doors & Locks 1 07-31-2009 02:31 PM
Bushings toastie Axles 12 08-13-2008 05:55 AM
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
