Old 09-21-2022, 04:03 PM   #1
1995 36' Classic 36
Batesville , Mississippi
P Chassis brake issue
1995 Classic parking brake will not engage when shifter is put in "Park". I understand the mechanics of the system, but I can not repair it myself. I am having no luck finding someone to repair. Does anyone know of anyone anywhere that does chassis work on Airstream Motor Homes? Sure would like to be able to use my unit, but is pretty much dead if you can't keep it from rolling!
Casey Lipe is offline   Reply With Quote
Old 09-21-2022, 04:28 PM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
The hydraulic auto park feature used in the early 90's is a double edge sword, with folks reporting an ebrake lockup at Hwy speed. You always have the "manual" emergency brake to keep it from rolling. Others have installed a Parking pawl in the transmission, which was omitted on vehicles above 16k pounds. You may have more luck finding a transmission shop to install the parking pawl than finding a shop to repair the Auto park feature (considering the huge liability it comes with)
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 09-21-2022, 08:13 PM   #3
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
Here is a link that Peter had shared with me. RV auto brake
I have put in the parking paw in our 350LE. The e-brake is now manual. Although auto park is disabled, it can be put back in working order with connecting the linkage from the shift selector, reattach pin in the linkage to the actuator and attach the wires to the pressure switch.
I still chock the wheels if on a incline, e-brake applied first then put into park.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Speaker Connection In and Out (Sprinter Chassis Issue?) vaboater Sprinter and B-van Forum 1 08-05-2022 04:05 PM
Still having Brake problems with P32 chassis Grandave Land Yacht/Legacy Motorhomes 14 04-21-2021 11:18 PM
Auto parking brake p32 chassis IPM Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2017 07:08 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Chevy Chassis Brake System 87MH Mechanics Corner - Engines, Transmission & More... 1 12-22-2004 01:51 PM
