07-29-2020, 09:24 AM
1987 32.5' Airstream 325
Windsor
ONAN Generator won't stay running
As part of my pre-camp systems check, I tried starting my ONAN generator.
It turns over and will run as long as you hold the start button "ON" but as soon as you let go it shuts off.
Thanks in advance for your consults,
Chris
07-29-2020, 09:52 AM
Richmond
, Kentucky
Chris
Chris, there is a glass fuse inside the control box. If the fuse is blown I believe the symptoms are as you describe.
Pull the cover from the control box and see if you can find the fuse.
PS, I hope I'm not thinking of a Koehler generator!
1975 24' Argosy Motor Home
07-30-2020, 05:59 AM
Windsor
ONSN Generator won’t stay running
Thanks Brad,
This is the fuse that is on the front of the generator, yes?
I have checked that but will get the magnifying glass out this time.
07-30-2020, 06:17 AM
Richmond
, Kentucky
Thanks Brad,
Assuming my memory is correct on the Onan, there is a fuse inside the cover as well. Requires the removal of four screws.
My problem is I worked just as much on a Koehler 6.5 as I have on an Onan 6.5 and it's been a number of years since I've dealt with either one.
07-30-2020, 09:19 AM
1986 25' Sovereign
Huntsville
Two things I'd start with is make sure you have plenty of gasoline in tank and check oil level on generator. Bad low oil pressure switch or low oil will cause that. What model of generator do you have?
07-30-2020, 12:29 PM
Murfreesboro
Fix Maybe
I have an Onan engine on my welder. That engine has two different jets in the carburetor. A Low Idle and a continuous run jet. My engine did the same thing. I think ir was just gummed up form bad gas. Anyway, I took the carburetor off and left it assmbled and soaked it over night in a bucket of carburetor cleaner. The next day I took an air hose and blew it out really good and put it back on. It rises great now. Just don't let it set for week in between starting the engine. I have it on my calendar each month to start all my small engines and let them run for about 20 mins.
07-30-2020, 02:02 PM
1988 32' Excella
Robbinsville
, New Jersey
Best to use a meter to check the fuses. I've seen fuses that were broken near the end so you could not see it was broken, maybe if you shook it you could see it move.
07-31-2020, 03:29 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I had a terrible time getting an Onan to start and continue to run. Besides, you could see it was getting so hot it was scorching the top of it's compartment. It turned out to be the cylinder head needed to be decarbonized. Viola, everything was great.
guskmg
09-08-2020, 07:21 AM
Windsor
Brad,
I pulled the cover off, this is where the “pullout “ fuse and “on/off” switch is located and found no fuse inside, justnthe solenoid.
Thanks for your reply
09-08-2020, 11:58 AM
Richmond
, Kentucky
Brad,
Is your generator a 6.5 NHE Onan? If so I have the manuals in pdf that I can provide links for. The service manual has a small troubleshooting section.
