Old 07-21-2022, 04:47 PM   #1
1982 28' Airstream 280
Cooper Landing , Alaska
OEM Toilet - 1982 Airstream Excella 28" Mh
What OEM toilet was used in the 1982 Airstream Excella 28' motorhome? I can find no nameplate data on it anywhere. It appears that the inlet control valve is leaking. When the foot pedal flush is held down, water leaks from behind the toilet. I am currently using a tightly coiled towel to absorb the leakage and minimizing the time the foot pedal plush is held down. I manually add water to the bowl and dump it with a quick depress of the foot pedal flush. That is keeping the toilet clean but is inconvenient to manually add flush water.
If anyone knows, please advise toilet mfgr. , model #, part#s for inlet water control valve and vacuum breaker.
Fred Hudspeth (aka xengineer)
Tyler, TX
Airstream located/stored in Cooper Landing, Alaska for summer use
xengineer is offline   Reply With Quote
Old 07-22-2022, 01:17 PM   #2
LM782's Avatar
1985 34.5' Airstream 345
Lexington , Massachusetts
A picture helps. Here’s what was installed in our ‘85 345. http://bdub.net/manuals/Aqua_Magic_Galaxy_Toilet_Op.pdf.
Luis
LM782 is offline   Reply With Quote
Old 07-25-2022, 01:01 PM   #3
Thanks much, Luis - 'same toilet. 'Got the nameplate data I was seeking from the same toilet in an Airstream trailer from CA that showed up here (at Kenai Princess/Cooper Landing Alaska). 'Have located needed parts at West Marine/Anchorage.
Tyler, TX
OEM Toilet - 1982 Airstream Excella 28" Mh xengineer Sinks, Showers & Toilets 0 07-21-2022 01:23 PM
"Larden" dump valves appear to be OEM in my 1990 Excella sbrianericks Waste Systems, Tanks & Totes 1 04-02-2022 04:33 PM
Source - OEM AC Condenser Replacement -1982 Excella 28' xengineer Classic Motorhomes 9 09-13-2016 12:27 AM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
