Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-22-2020, 10:46 PM   #21
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Good job getting home! The first thing that I would check on your stall is the electric fuel pump back near the tank. It may be on a switch in the cockpit. You should hear it running with the ignition on.
Waipio Rim is offline   Reply With Quote
Old 08-23-2020, 06:44 AM   #22
1985 34.5' Airstream 345
Oceanside , CALIFORNIA
Glad to read that you, your wife, and the coach made it back home safe and sound.
Many of the motorhomes have 3 fuel filters that you may want to verify are not restricting fuel flow during high demand. The first is at and/or in the fuel tank, the second can be found along the fuel line to the carb (on my 345 it is about where the step is), and the third is just inside the carburetor housing where the fuel line attaches.
Congratulations once again and enjoy the adventure of restoring one of these classics!
RETIREDRIVER is offline   Reply With Quote
Old 08-24-2020, 02:21 AM   #23
1987 34.5' Airstream 345
Auckland , New Zealand
If you take a look at these gas tanks, 80gal, long flat n wide ,with an external electric fuel pump level with tank bottom, it has to suck up to top off tank then down to the pump and pushed 30ft forward. Yes filters need attention but as I have found out if tank is low on fuel say quarter or less and on a long steepish hill allows the shallow design tank to gulp air into the fuel line , we can all imagine the outcome, nightmare stuff.
I'v overcome this design fault my own way, but you could just keep tank near half full if on long hills... expensive and heavy.
Rus
Voltair is offline   Reply With Quote
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 4 08-07-2020 11:13 AM
Pump Noise / Vibration - 2019 AS GT - Newbie olgoat Water Heaters, Filters & Pumps 26 02-07-2019 11:17 AM
Newbie - water pump noise annedfriend Plumbing - Systems & Fixtures 27 05-30-2018 02:50 PM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 12:18 PM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 07:23 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
